84 CJ7 Stock Differential Gear Ratios - HELP - JeepForum.com
post #1 of 5 Old 11-07-2008, 12:20 PM Thread Starter
SSKW69
I'm trying to figure out what the stock differential grear ratios are on my CJ7. The dealer can't help as the computers don't contain the information I'm looking for. I got rid of the stock tires and replaced them with 31 inch tires. Now I have no power in 5th gear. Can someone point me in the right direction?
SSKW69 is offline
post #2 of 5 Old 11-07-2008, 12:34 PM
starfire340
1983 CJ7
Search web for code locations on front axle. I did and located the number (stamped in tube on Drivers side of front differential, have to scrape the paint and rust off, but it's there. Actually went to the Spicer website and decoded it. Found out I had 2:72's (Yuk). Could also simply count rotations of tire vs driveshaft and calculate from there.
starfire340 is offline
post #3 of 5 Old 11-07-2008, 12:35 PM Thread Starter
SSKW69
Thanks for the advice. I'm heading down to the garage now to see what I can't find out.
SSKW69 is offline
post #4 of 5 Old 11-07-2008, 03:31 PM
bdmonist
WTF is that?
bdmonist's Avatar
Jack it up and count the tire rotations vs drive shaft rotations. The tag tells you nothing, you have no idea what upgrades have been performed in the last 20+ years.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #5 of 5 Old 11-07-2008, 03:50 PM
bleoh
http://www.jeeptech.com/axle/amc20.html
My 1984 (widetrack) CJ7 5sp rear had a B stamped on the pass side of the center section when looking at it from the rear. This means 3:31 per the above website.
I have 31" tires and my 5th gear is fine. But keep in mind I have a fresh 4.2, 30 over with a HO 4.0 head and custom fuel injection.
bleoh is offline
Gear ratios & final drive ratios Squish Jeep CJ Forum 5 10-23-2008 07:40 PM
gear ratios bohmerjr Jeep CJ Forum 3 03-01-2008 09:46 PM
gear ratios on my AMC 20? ncmx1 Jeep CJ Forum 5 05-12-2007 06:13 PM
what are the stock gear ratios for 79 w/ the manual 3 speed & 4.2? jborkowski Jeep CJ Forum 1 03-10-2007 11:25 AM
gear ratios???? mike4089 Jeep CJ Forum 11 02-18-2007 12:07 PM
