84' cj7 Replacement wiring harness issues! - JeepForum.com
post #1 of 8 Old 01-25-2012, 01:05 PM Thread Starter
Tom1382
I am replacing a hacked up harness with an oem one from another cj and I cant get it to turn over. No power at all! I think the problem is at the starter solenoid. The old harness seems to be modified just enough to get the jeep to run, no power to anything, else but the engine ran like a champ. I put in the new harness and I have 2 light blue wires at the starter solenoid with no where to go. Im not sure the solenoid is stock. I think these are the fusible link wires but i cant figure out where they go. Any info would be appreciated. Thanks. 1984 cj7 258 weber carb.
Tom1382 is offline
post #2 of 8 Old 01-25-2012, 01:11 PM
John Strenk
John Strenk's Avatar
1976 CJ5
First does it not run or not crank?
If they are the original color code, blue should go to the "S" on the starter solenoid the other to the ignition module. Possibly to a NSS depending upon year.
The stock starter solenoid should have two small terminals. An "I" that runs to the (+) of the ignition coil (Red) and an "S" that comes from the ignition switch (Blue).
John Strenk is online now
post #3 of 8 Old 01-25-2012, 01:19 PM Thread Starter
Tom1382
No it doesnt run. The new harness seems to be stock and in good shape. And it ran fine this morning when i removed the old harness so im pretty sure all my grounds are ok.
Tom1382 is offline
post #4 of 8 Old 01-25-2012, 02:35 PM Thread Starter
Tom1382
OK, I think it has to be a fusible link issue. the only thing that seems like it might be a fusible link (no idea!) is a yellow wire connector on a red wire on the battery cable side of the ignition solenoid. it seems fine though. Any other fuse or grounds under the dash perhaps that i might check?
Tom1382 is offline
post #5 of 8 Old 01-25-2012, 03:44 PM
keith460
Jeep. There's Only One
keith460's Avatar
I have an 84' CJ so this picture may help. All CJ's are pretty much wired the same way.
1984 CJ-7 Renegade
keith460 is online now
post #6 of 8 Old 01-25-2012, 06:40 PM Thread Starter
Tom1382
thanks Keith and John. I got it to fire right up after I loosened and re tightened all my connections. I think it was a rubber wire boot that wasn't letting my wire contact on the solenoid. took 7 hours to figure that out!
Tom1382 is offline
post #7 of 8 Old 03-13-2012, 12:22 PM
greene86cj
Quick question for Keith. I noticed in your pic your solenoid is wired with the positive lead from your battery that shares the post with the lead to the alternator is on the "I" side of the solenoid, ie the firewall side. The positive lead to the starter is on the "s" side. Mine is wired the opposite. Does it matter which post, or are they interchangeable? Also, I have an 999 auto and I am wondering if my n safety switch is connected correctly (where does it tie to the solenoid at?) can you override the ns switch? Sorry to high jack the thread.
greene86cj is offline
post #8 of 8 Old 10-26-2013, 08:01 PM
MigBike
A volt meter is MUST HAVE in ones tool box in my opinion, mine just saved me from spending another 4 hours trying to figure out the ignition wiring with my painless wiring harness, which by the way, is not painless at all... especially since their help hotline and website are both down! and as for your terminal post question green, it should be interchangeable, there is just a bridge inside that connects the two terminals when the solenoid becomes energized.
MigBike is offline
no power , restoration , solenoid , wiring
Wiring Harness ? WayneMeuir Jeep CJ Forum 16 02-06-2010 06:14 PM
Wiring Harness ID chet44 Jeep CJ Forum 2 01-18-2009 10:12 AM
Anyone got a CJ-7 wiring harness?? h1driver Jeep CJ Forum 5 10-14-2008 12:06 PM
YJ Wiring Harness in CJ??? FoMoCoSVT Jeep CJ Forum 7 07-02-2008 05:46 AM
ez wiring harness nichols077 Jeep CJ Forum 3 01-07-2007 12:24 PM
