84 CJ7 Rear Driveshaft - JeepForum.com
post #1 of 4 Old 06-04-2013, 12:27 PM Thread Starter
Chrisfol82
I have an 84 CJ7 with about a ~4 1/2" lift, dana 300 tcase, and AMC20 rear.
Currently i have the stock drive shaft and maybe about a 1/2" tcase drop.
Offroad i dont seem to have much trouble, but on road there is a pretty noticeable vibration. I didnt have time to fix it in the past, but now i do and would like to get it working better.
I want to swap to a double cardan shaft but had a few questions.
To change my rear axle input angle to point up towards the tcase output, shoudl i go with angle shims, or weld on new perches? I think im leaning towards welding on new perches.
On the tcase end with the doubel cardan shaft can i use the stock tcase output yoke? Looking at the tom woods website for CJ's it looks like they reccomend a flanged connection rather than the stock type yoke, why is this?
I understand i coudl use an XJ front shaft and tcase output. Anyone done this? The tcase output matches up with the Dana 300 tcase correctly i assume and i just ahve to shorten the shaft? When i shorten is do i make it so that the shaft is in the middle of its stroke at normal ride height?
When i rotate my rear axle to work with the double cardan shaft is it ok to run with the stock driveshaft until i get my new shaft installed?
Any help would be appreciated
Chrisfol82 is offline
post #2 of 4 Old 06-04-2013, 02:06 PM
capt205
1983 CJ7
Just finished up the lift on mine...4.5 RE lift, left out the case drop. Welded on new perches to index the rear end. I went with a double carden shaft, so changed out the output on the D300.
No vibrations what-so-ever.
capt205 is offline
post #3 of 4 Old 06-04-2013, 03:17 PM
82JeepCJ7
1982 CJ7
I built my own DC rear from a XJ front. The output yoke on the NP231 has the same splines as the Dana 300 (26). It bolts right up. I spent $50 on my complete setup.
Full write up on it.
http://www.jeepforum.com/forum/f8/di...ne-cj-1444192/
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #4 of 4 Old 06-04-2013, 05:48 PM
gojeepin
1983 CJ7
I did something similar... I used a shortened XJ front driveshaft for my son's TJ.
I used an NP231 yoke with a Tom Woods driveshaft on my CJ7.
I don't like shims for either axle. I welded on new perches.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
