84 CJ7 and my trailer hitch woes - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 84 CJ7 and my trailer hitch woes
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13
Unread 07-18-2015, 11:29 AM   #1
scottyDive
Taking a family trip recently with the CJ7 I bought a receiver hitch and bolted it on to the rear c channel. I knew the c channel was pretty thin, but all I was going to use the hitch for was holding some bikes via a bike rack and some beach chairs and cooler using a cargo attachment. I was lucky that I was not on the highway, in fact I was about 400 feet from my destination when the crash sound came and two bikes fell into the road and the third and fourth stayed on. One of the bikes on the bike rack has a bent wheel, the two that went in the road are toast but thanks god no one was hurt. If this was on the highway it could have been catastrophic. Looks like a new heavy duty c channel bumper is in my future.
Please be aware that the stock bumper or whatever it is considered is not strong enough unless somehow reinforced first
Scott
84 CJ7 258, 2150 TFI nuttered 2" shackle lift 33's
70 Jeepster Commando 225 HEI 3spd 2" lift
scottyDive is offline   Reply With Quote Quick reply to this message
Unread 07-18-2015, 01:00 PM   #2
Dngrs1
1979 CJ7
Fender washers or a steel plate on the inside may have prevented that.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2015, 01:07 PM   #3
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
They would not have prevented that failure.
The correct hitch (or bumper) install includes frame tie-in brackets of some type. The hitch shown has existing slots at each end of the hitch. The frame tie-in brackets transfer the load from the hitch to the frame, instead of having the cross member to bear the load.
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 07-21-2015, 08:18 PM   #4
scottyDive
Can anyone guide me in what my options are for changing this out? I was originally thinking on a stouter c channel, but didn't know about the reinforcement brackets. Did you make them or are they stock? For my application I wouldn't think I would need them but would rather over build than under. I prefer the stock look, but if there is a compelling reason to go another direction I am all ears
Scott
Unread 07-21-2015, 09:39 PM   #5
CSP
Do a search on rear crossmember. Someone makes a thicker version but the name escapes me.
x2 on tying that hitch into the frame even if you get a thicker xmember.
CSP is offline   Reply With Quote Quick reply to this message
Unread 07-21-2015, 10:00 PM   #6
Boomer
1982 CJ8
Looks like the OP already found ChiefWahoo over at CJ-8.com
Boomer is online now   Reply With Quote Quick reply to this message
Unread 07-22-2015, 03:39 AM   #7
BagusJeep
BagusJeep's Avatar
1981 CJ7
A steel plate on the inside MAY have prevented the bolts pulling through at that time but that section is just not very stout. A CJ is a lightweight vehicle and some bits are a bit thin.
The receiver hitch you have can work with the bracing angles behind the existing crossmember as long as you through bolt.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 07-22-2015, 05:38 AM   #8
wellmax
my old 1984 jeep has the std jeep hitch,
a bent piece of flat stock,
not meant for anything over a small lawnmower trailer with very little tongue weight.
plus with the short wheel base, jeeps are kind of squirrely pulling anything..
wellmax is offline   Reply With Quote Quick reply to this message
Unread 07-22-2015, 11:26 AM   #9
CJ7-Tim
CJ7-Tim's Avatar
Fix or replace the rear cross member. While you are doing that, install the necessary frame tie-in plates, either store bought or home built.
