84 CJ7 i6 258 ..first transmission issues.. Need HELP - JeepForum.com
post #1 of 13 Old 10-14-2013, 03:32 PM Thread Starter
rickscj7boom
Hello Fellow Jeepers... My issue is while driving in 5th gear down the road I heard a clanking noise that what felt was coming from right under the gear shifter, as I pulled over and down shifted it did the same noise with all the gears except 4th gear.. after costing it to a stop I got under the jeep to take a look. I known that the TC has a lil leak that I haven't fixed, but I wasn't aware that the tranny also had a leak and it ran out of fluid is my guess.. I sent my buddy In his jeep to get me some trans oil, shell station only had 2 quarts and the tranny took them both without over spill, I made it home but now need help in where to start looking to fix this or what could of broken.. after I put oil it still clanked in every gear other than 4th gear..
I will get under the jeep tonight and see what kind of tranny I have and take some pics
rickscj7boom is offline
post #2 of 13 Old 10-14-2013, 05:58 PM
LumpyGrits
Sounds like you 'smoked' the tranny for sure and it's rebuild/replace time.
You better ck both diffs to see if they are low.
Got to learn about preventive maintenance.
FYI, don't use std 85w-90 gear oil. The T5 was never spec'd for that lubricant. You want 75W-80 syn. gear oil.
A bottle of Lucas power steering stop leak works well in either the tranny or t'case.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 13 Old 10-15-2013, 11:09 PM Thread Starter
rickscj7boom
Thanks for the info lumpygrits, so today I called a used jeep parts in San Diego and they guy on the phone said that around $550 - $600 plus tranny trade would get me a "used good" tranny. With 3 months warranty on it. My question to you sir does that sound like a ok deal or should I look elsewhere .. I do have the Mexico border 30 min away and could always cross over and take my tranny for them to rebuild, I'm currently working on getting a price on that option.. Thanks
Rick
post #4 of 13 Old 10-15-2013, 11:25 PM
LumpyGrits
$500-$600 for a 'box' you have no clue about it's history, is not how I would go.
Why don't you just get yours rebuilt?
LG
post #5 of 13 Old 10-16-2013, 03:27 AM
BagusJeep
1981 CJ7
SOunds like you have a T5 problem, so this is your opportunity to either rebuild that old box or upgrade.
The 650 for a used box is steep, it is only a T5 light car transmission.
Do you need 5th gear? If not there are stronger and shorter 4 speeds out there, such as the medium duty T176. You will need the box, driveshafts and boots and will have the simple fab of the transmisison tunnel cover. With buying the secondhand parts and rebuild you coul dbe looking at 600 but the end result will be a reliable box that will take some abuse.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 13 Old 10-16-2013, 04:23 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
As previously stated, you have a T5 problem. Weak tranny. If it were me, I would replace it with something better. Yesterday I saw a T176/D300 combo for sale for $300. Will post up the link if I can find it again. Personally, I wouldn't waste any time or money on another T5 just to have it crap out on me again. That's why I'm now running a T18.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #7 of 13 Old 10-16-2013, 06:06 AM
keith460
Jeep. There's Only One
keith460's Avatar
For the T5 trans, you may get lucky and only need to replace a failed bearing and maybe the shaft it rides on. Rebuild kits cost around $200 but you wont know what you need until you pull it.
Your profile only shows the 258 engine and 35" tires. If your CJ has the standard 2.73 gears, 35" tires and the T5 trans, that combo will never get you far no matter how many times you rebuild or replace that transmission. It is entirely to much stress for that light duty transmission is capable of taking. Invest in some 4.56 or 4.88 gears if you want to keep the T5 for its overdrive.
1984 CJ-7 Renegade
keith460 is offline
post #8 of 13 Old 10-17-2013, 11:50 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
T176/D300 combo
http://www.hardlinecrawlers.com/foru...?topic=28450.0
post #9 of 13 Old 10-17-2013, 05:21 PM Thread Starter
rickscj7boom
thanks guys for the info/links, I think I will take the tranny out and learn how to rebuild it on my own time... and also keep an eye out for a used tranny around town.. I also found this link here on the forum with the factory manualsl, I printed out the P. T-4 & T-5 transmission overhaul , would that be the correct guide to follow for my t5?
post #10 of 13 Old 10-17-2013, 08:58 PM
PERK
there's 2 T-5s for sale on craigslist up here in the bay area for way less than that price
PERK is offline
post #11 of 13 Old 10-18-2013, 04:06 PM Thread Starter
rickscj7boom
Hey guys, will a Borg Warner T5 Transmission out of a 1985 Jeep CJ-7 fit my jeep.. swap out?
post #12 of 13 Old 10-18-2013, 04:59 PM
shadoow
This is good info and worth thinking about. You're kinda between a rock & hard place with your setup so you need to make a plan on how to get your jeep set up better; either upgrade your trans to a T176 (which will require other changes like driveshaft lengths, bell housing modification or change out, different tunnel cover, etc) or change out your wheels and tires or re-gear as mentioned above. If all you do is replace/fix the T5 you'll likely be in the same predicament down the road.
as far as the BW T5 bolting up to your bellhousing the answer is yes it will. All the T4 and T5 transmissions were made by BW including the one that's in your jeep and broke. Here's a link to jeep transmission info:
http://www.novak-adapt.com/knowledge...on_gateway.htm
shadoow is offline
post #13 of 13 Old 10-18-2013, 06:00 PM Thread Starter
rickscj7boom
thanks! Great info..
