84 CJ7 Dies when brakes are applied - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 84 CJ7 Dies when brakes are applied
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 05-11-2014, 08:44 AM   #1
jeepjockjr84
Every time i come to a stop sign my 1984 CJ7 wants to stall when i apply the brakes, the rpms drop and the engine will stall unless i hit the gas at the same time i apply the brakes to keep the rpms up.....Vacuum leak some where? Power brake booster need replacing? any ideas are welcome, Thanks
jeepjockjr84 is offline   Reply With Quote
Unread 05-11-2014, 08:49 AM   #2
1949er
You pretty much got it , plug the booster vac. line and hit the brake & see if it dies.
1949er is offline   Reply With Quote
Unread 05-11-2014, 09:34 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
A carboned up EGR also can cause that. To test, just unplug it and block the line.
The carb itself can have idle issues, but those don't just happen when braking.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
