84 CJ7 Dana 30 Spindle. - JeepForum.com
post #1 of 11 Old 05-08-2013, 08:34 PM Thread Starter
Lookinsketchy
Pulled the hub and spindle today and I noticed some rough spots on the spindle in the middle. Is that enough to warrant a replacement?
Lookinsketchy is offline
post #2 of 11 Old 05-08-2013, 08:45 PM
Knucklehead
1973 CJ5
Clean it up with a wire wheel and reuse it.
WJ Build: http://www.pirate4x4.com/forum/jeep-cherokee/2171458-wj-build-sd-axles.html
Knucklehead is offline
post #3 of 11 Old 05-08-2013, 08:59 PM
lucdog
1980 CJ5
Nope doesn't matter, what does is the seal mating surface.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4 of 11 Old 05-08-2013, 11:07 PM Thread Starter
Lookinsketchy
Thank you for your replies.
post #5 of 11 Old 05-09-2013, 01:56 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
Might be a good time to high steer it while you're there, no? Just trying to help ya spend cash .
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #6 of 11 Old 05-09-2013, 08:39 AM
CSP
Where did high steer come from based on the information given? For all we know it could be bone stock.
CSP is offline
post #7 of 11 Old 05-09-2013, 08:48 AM
hutch1200
hutch1200's Avatar
1979 CJ7
Hi steer
I looked at his profile? He already had his original answer. It was just a suggestion. If I had mine that far apart, I'd do it. I guess I shouldn't offer opinions on upgrades or changes based on assumptions if it's gonna upset people so much.
post #8 of 11 Old 05-09-2013, 08:57 AM
CSP
Who's upset? I was just curious where you came up with that as it looked like it came straight out of left field.
CSP is offline
post #9 of 11 Old 05-09-2013, 09:11 AM Thread Starter
Lookinsketchy
As I was removing the inner and outer races, I tagged the inside of the hub with the punch and created a burr. If I can remove it, I assume that would not create any issues ?
post #10 of 11 Old 05-09-2013, 09:21 AM
CSP
Knock it down with a file and emory cloth and it will be fine. It's not a wear surface with anything moving against it.
CSP is offline
post #11 of 11 Old 05-09-2013, 09:43 AM Thread Starter
Lookinsketchy
CSP,
Thank you for the suggestion. Won't do that again with the punch!
