84 CJ7 CARB VENT / FUEL Filter question? - JeepForum.com
post #1 of 13 Old 06-24-2013, 01:14 PM Thread Starter
rickscj7boom
I'm changing out the fuel filter that the PO installed with the correct filter that it needs, so with that said I know that the top fuel filter outlet is the return to the gas tank right? So I was looking for any fuel line that goes back to the tank and the only one I found going back is connected to the top of my carb , here is a link of a fellow jeep brother labeled it with a number 7, do you guys think I can use that line and just cap the one from the carb ..
http://www.flickr.com/photos/7605628...h/2910870730/#
or try this
http://www.flickr.com/photos/7605628@N05/2910870730/
labeled #7
I will post pics of mine when I get out of work...
rickscj7boom is offline
post #2 of 13 Old 06-24-2013, 02:11 PM
LeePrather
1978 CJ5
If you have 2 lines coming out of your gas tank, the larger is your fuel, the smaller is your return line. If you do have 2, follow them under the vehicle to the engine compartment. No telling what someone did to stop or plug the return line. Should have one from fuel tank to bottom line of filter to fuel pump to carb. Should have one from tank to top line of filter.
LeePrather is offline
post #3 of 13 Old 06-25-2013, 09:45 AM Thread Starter
rickscj7boom
I checked the line that is connected to the top of my carb and blew on it and i could here some noise in the gas tank, so that tells me that it's connected to the tank right? Now can i connect my fuel filter over flow to that line?
post #4 of 13 Old 06-25-2013, 10:00 AM
LumpyGrits
Connected to you carb?
That's the feed line to your carb
Why would you connect a return line to your feed line?
You really need to get an FSM.......
LG
LumpyGrits is offline
post #5 of 13 Old 06-25-2013, 10:00 AM
John Strenk
John Strenk's Avatar
1976 CJ5
No vents on the carb should be connected to the tank.
But maybe the PO wanted to hook up an open port someplace...
Should be a tube going down the side of the block near the motor mount.
something like this...
just to the left of the spring.
John Strenk is online now
post #6 of 13 Old 06-25-2013, 10:23 AM Thread Starter
rickscj7boom
Oh crap!, yup there is a line that is connected from the top of my carb bowl and it goes to the tank , its the number 7 on the link above...
post #7 of 13 Old 06-25-2013, 10:27 AM
86cj74.2L
86cj74.2L's Avatar
That's your return line. The bowl vent should go to the evap canister.
86cj74.2L is offline
post #8 of 13 Old 06-25-2013, 10:28 AM Thread Starter
rickscj7boom
thanks john, i'm guessing that fuel line tube one your picture is the one that the PO used and just connect that carb vent to it, it's just lower than how your picture looks, maybe it got bent down or cut short.. that's probably my line for the fuel filter overflow?
post #9 of 13 Old 06-25-2013, 12:34 PM
John Strenk
1976 CJ5
Yeah, mine sits lower also. There is just a single clamp holding it to the block.
If you look lower you should see it hooked up to another rubber hose into a line that goes to the back of the jeep.
That port was originally used as a fresh air sourse for the exhaust heated choke. It should be plugged if not used. What choke do you have?
Waiting for your pictures.... if you can post them....
post #10 of 13 Old 06-25-2013, 07:39 PM Thread Starter
rickscj7boom
Hello,
Here are a few pics on one of them i'm hold on to the line and a link to a vid...
http://youtu.be/zb0aD9otHZI
post #11 of 13 Old 06-26-2013, 03:01 AM
John Strenk
1976 CJ5
Yeah, that looks like the fuel return line alright.
post #12 of 13 Old 06-26-2013, 08:36 AM Thread Starter
rickscj7boom
thank you for your help sir... I will install my new fuel filter after work and see what happens
post #13 of 13 Old 06-26-2013, 09:07 AM
John Strenk
1976 CJ5
Just make sure it's intact all the way to the tank....
