84 CJ7 Ball Joint Install Issue - Page 2 - JeepForum.com
post #16 of 19 Old 05-18-2013, 08:17 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
you will need to change the fitting to the needle type or else the u joint will hit it......
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #17 of 19 Old 05-18-2013, 09:54 AM Thread Starter
Lookinsketchy
Red,
I plan on just installing the small bolt on the upper ballpoint vs putting the zerk on.
Lookinsketchy is offline
post #18 of 19 Old 05-18-2013, 10:21 AM
CSP
I do the same thing. Grease them good before you install everthing and keep the zerk fitting around so you can grease them in the future.
CSP is offline
post #19 of 19 Old 05-18-2013, 11:25 AM Thread Starter
Lookinsketchy
CSP,
Thank you for the reply.
