84 cj7 258 Won't start! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 84 cj7 258 Won't start!
Steering and more from Ruffstuff!Ruffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread Today, 08:25 AM   #1
mastercraftka
mastercraftka's Avatar
My jeep sat for several weeks because of rain so when the sun finally came out I fired her up and it started had a little carb fuel issue but got it smoothed out. I parked it went back several hours later to start it up and nothing not even a click. My key wasn't left on because I had it in my pocket. I pulled my truck up to jump start and would barely turn. I let it set for awhile charging from my truck and got it to turn over some but it was week. I finally gave up because it wasn't turning over now. I checked my connections changed to the other battery on my diesel truck thinking I needed a better ground and nothing. I then just went and got the battery charger and charged over night and all day on slow trickle charge. Went there yesterday after work and not even a click.
Battery shows charged and it is about 2 years old or less. I checked the connections on the solenoid and starter nothing looks loose or corroded.
Any ideas. Try a different battery? sometimes i know they say they are charged but actually are not?
1984 CJ 7
1948 CJ 2A
1982 CJ 7
1981 CJ 7
mastercraftka is online now   Reply With Quote Quick reply to this message
Unread Today, 09:26 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
One sneaky neglected ground is where the neg cable hooks to the block.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
