84 CJ Ball joint question - JeepForum.com
post #1 of 9 Old 09-13-2009, 06:48 PM Thread Starter
kirkhbauer
just installed a new set of moog ball joint set everything to spec except split ring torque to 45 in stead of 50Lb how stiff should the knuckels be they are stiff but still moveable, not a one had job but not straining with two hands. Is this normal? will I have problems returning in a corner. it did not return before hopeing new ball joints will take care of this.. Thanks everyone
Life's to short to be stuck behind a desk!
kirkhbauer is offline
post #2 of 9 Old 09-14-2009, 08:32 AM
CSP
Sounds normal with new balljoints.
CSP is offline
post #3 of 9 Old 09-14-2009, 04:24 PM Thread Starter
kirkhbauer
so run it?
so run it and re check?
post #4 of 9 Old 09-14-2009, 08:02 PM
gojeepin
1983 CJ7
Why didn't you set the preload to 50 ft lbs?
You said it didn't return to center... It could help but did you change the suspension in any way?
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #5 of 9 Old 09-14-2009, 08:21 PM
ACAD_Cowboy
1980 CJ7
The 50lb preload is used to stretch the metal not control how stiff the joint appears. If you don't preload the joint during installation the metal will stretch later and leave you with a lot of slop. Preloading suspension components is the same a torquing a head bolt; steel stretches up to a point and it's that point you need to get to for a fatigue free joint.
-= Francis =-
These, in the day when heaven was falling, The hour when earth's foundations fled, Followed their mercenary calling, And took their wages, and are dead.
Their shoulders held the sky suspended; They stood, and earth's foundations stay; What God abandoned, these defended, And saved the sum of things for pay.
A.E. Housman
ACAD_Cowboy is offline
post #6 of 9 Old 09-14-2009, 08:59 PM Thread Starter
kirkhbauer
at 50 pounds on the split nut the ball joints were not movable with out two men and a boy. did research and sugestion was to go to 45 lb to help with return to center after a turn
post #7 of 9 Old 09-14-2009, 09:04 PM Thread Starter
kirkhbauer
the jeep has a 4 inch lift with caster reset to 6 degrease has the more HD box mount and cross brace will soon have currie HD tye rod's and ends going to Micky thompson 8x15 classic rims and BF 33x10.5x15 KM@ tires
post #8 of 9 Old 09-15-2009, 06:20 AM
JeepHammer
Running On Empty...
1973 CJ5
I know this is a silly question,
But did you torque the bottom ball stud FIRST? before you put the split ring in and torque it?
The bottom has to be done FIRST,
Torque to about 75 Ft.Lb.
Then the split ring to about 50 Ft.Lb.,
Then the top nut to about 100 Ft. Lb.
If you don't do torque the bottom first, you will have all kinds of problems...
Did you grease the ball studs yet?
Adding grease often makes them MUCH easer to work with.
Mine were Moog, and VERY stiff when first installed, but they seated in just a mile or two and work PERFECTLY now.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #9 of 9 Old 09-15-2009, 07:53 AM
MikeMCJ
1951 M-38
I've read the same thing. Something about a Jeep (dealer) mechanic remembered wandering until they started to torque to 45. Too much preload is a bad thing too.
MikeMCJ is offline
Ball Joint Question rixcj Jeep CJ Forum 10 08-17-2009 05:21 PM
Ball joint Question BAH07 Jeep CJ Forum 10 09-02-2008 05:27 PM
dana 30 ball joint torque question? rcgkaw Jeep CJ Forum 3 09-11-2006 08:45 AM
ball joint shims or adj ball joints? jm708 Jeep CJ Forum 9 10-26-2005 09:45 AM
CJ7 Ball joint question heytat Jeep CJ Forum 6 01-17-2003 03:20 PM
