84 CJ 7 starts + idles for 2mins and cuts off - JeepForum.com
post #1 of 13 Old 04-03-2010, 02:30 PM Thread Starter
SeaJay7
it will start fine and idle for about a minute, but after that it chokes off like it's not getting the right fuel mix/air mix and then cuts off. All the emissions stuff has been removed and pluged up. The only hosing remainin are the pcv valve and the vacuum advance. I. Does anyone have an idea off what could be wrong. Vacuum line leaks are my only idea, gonna start checkin them later. One more random question. Should the vacuum advance be atached above or below the carb/manifold plate? Thankyou for your time and help. -Anthony
SeaJay7 is offline
post #2 of 13 Old 04-03-2010, 03:39 PM
IdahoJeeper
Anthony....how about more info so we can assist better....what engine, what carb, what mods do you have? Do you still have/use the fuel filter with the "return" line? Just need some more info and there are lots of guys here that will gladly assist.
Good luck!!
'95 ZJ Laredo, 4.0L, Auto, 225K, Forest Grn
'98 ZJ Laredo, 4.0L, Auto, 210K, White
IdahoJeeper is offline
post #3 of 13 Old 04-03-2010, 06:53 PM
littleturner76
1984 CJ8
You should probably give more details, like: was your Jeep running fine and this just started, or has it been parked, or did you just remove all the emmissions ect..............Check this out, kinda sounds like a problem I had. I changed just about everything I could before I tried the gas can. Read this post and it might help you narrow your problem down and save you some headache.
http://www.jeepforum.com/forum/f8/je...-2-min-783211/
1984 CJ8 Scrambler, 258, MC2100, daystar 1", 4" Skyjacker Soft Ride, 31X10.5 on stock wheels, raptor lined.
littleturner76 is offline
post #4 of 13 Old 04-03-2010, 07:11 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Unplug the line that went from the charcoal can to the tank. Let the tank breathe, and it'll run. Better thought - connect the charcoal back up so you don't have to smell the gas fumes as it vents out..
Rick
Cutlass327 is offline
post #5 of 13 Old 04-04-2010, 07:26 AM Thread Starter
SeaJay7
IdahoJeeper - the engine is a 258 inline 6 (5 speed). The carb is a Carter 0 (2731). I honestly don't know what the zero offest on the carb denotes. here's a link to the carb plate with all the info. http://i954.photobucket.com/albums/a...4-03185417.jpg
Littlturner76 - I got it cheap because of that. It was sitting for a bit, but ran fine to get gas to take it home, but then we came back to the guy we bought it from and parked it out front to come get later. When we came back it would start and stay running when you tap the accelerator, however if you let off it would cut off.
Cutlass327 - I'll try that.
Thankyou guys(and gals)
I also just put up some more photos
here: Pictures by SeaJay7 - Photobucket
And here are two visual questions.
http://i954.photobucket.com/albums/a...carbhelp-1.jpg
The original is here if you can please go in paint and redraw the two or 3 hoses in question correctly and reupload to imgur or somewhere please and thankyou.
http://i954.photobucket.com/albums/a...4-03190903.jpg
Here's the second question:
http://i954.photobucket.com/albums/a...utterfly-1.jpg
That is as far as the carb butterfly will close, is that enough because I was always under the impression it should be flat.
Thankyou guys for your time and help.
SeaJay7 is offline
post #6 of 13 Old 04-04-2010, 07:37 AM
Scooter402
That's a choke flap...supposed to be open (all the way) when the engine is warm...could be at least a big part of your problem.
Scooter402 is offline
post #7 of 13 Old 04-04-2010, 07:45 AM Thread Starter
SeaJay7
The engine is off in all of these photo's.
SeaJay7 is offline
post #8 of 13 Old 04-04-2010, 07:51 AM
Scooter402
Okay, that's fine. It doesn't necessarily "need" to be flat....all depends on the cold running/starting characteristics of your engine. If it starts up fine when its cold, there's no need to adjust the choke flap closed any more than it is.
What I am trying to say, however, is that if the choke flap remains in that position after 2 minutes of running, then the engine "begins to run roughly, as if it is not getting the right fuel/air mix, then dies" this COULD be part of the issue...choke flap blocks off airflow into the carb, richening the fuel mixture. Great for cold starts, kills it when the engine is warm. I'd make sure that your choke is opening up enough when the engine is running/warm, that's all I was saying.
post #9 of 13 Old 04-04-2010, 07:59 AM Thread Starter
SeaJay7
Ah ok, thankyou. How would i go about adjusting the choke flap?
SeaJay7 is offline
post #10 of 13 Old 04-04-2010, 08:17 AM
VACJ7
VACJ7's Avatar
If you have not downloaded the Factory Service Manual yet, get on it. Can't live without it.
http://www.jeepforum.com/forum/f8/84...ml#post6991784
VACJ7 is offline
post #11 of 13 Old 04-04-2010, 08:25 AM Thread Starter
SeaJay7
awesome, downloading it now, thankyou
SeaJay7 is offline
post #12 of 13 Old 04-04-2010, 08:40 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Looks like you still have most of the emission parts to me.
If I read your post correctly,
It will stay running, but you have to keep the rpm's up when it wants to die.
Sounds like the carb needs rebuilt.
LT1CJ7 is offline
post #13 of 13 Old 04-04-2010, 09:01 AM Thread Starter
SeaJay7
ok, thankyou. sorry for double posting
SeaJay7 is offline
cj7 , idle , pcv , vacuum advance
Jeep cuts out??? Jeepguy95 Jeep CJ Forum 1 06-07-2009 02:00 AM
258 HEI Idles, But will not rev. jcal73 Jeep CJ Forum 5 08-11-2008 01:11 PM
Idles but then dies out Bard Jeep CJ Forum 9 12-05-2005 04:11 AM
Starts fine, idles fine, but won't go.....can't figure it out fromme Jeep CJ Forum 4 08-04-2005 07:23 PM
CJ-7 cuts out at 45 -50 mph tnscout Jeep CJ Forum 23 05-30-2005 08:03 PM
