'84 CJ-7 "restore" project - Page 4 - JeepForum.com
post #46 of 191 Old 02-18-2014, 09:33 AM Thread Starter
smbundy13
1980 CJ7
Originally Posted by dg6772 View Post
I had to use innertube first,then I found some belting for some sort of conveyer.
BTW, my new skid also did not have a strap to hold tank into it. I had to add the strap above the tank on the jeep so when installed the strap holds the tank in place. It is from jc Whitney.
Dave in Muskegon using JeepForum
yeah I am going to have to buy a new center strap... might have to buy the new side straps but am not sure... they aren't that expensive.. less than $15 a piece.
DD - 2013 Ford F150 Platinum Eco-Boost
1980 CJ-7 rehab in progress
smbundy13 is offline
post #47 of 191 Old 02-18-2014, 09:33 AM
dg6772
Originally Posted by Matt1981CJ7 View Post
Be aware, there are other modifications that may be necessary with a body lift. These include:
1. Clutch linkage
2. Gas tank filler hose
3. Fan shroud
4. Steering shaft
Matt
Matt is right with this. The only thing I didn't have to change was my filler hose. I have a 1 1/2" lift (3" cut in half) it fit fine. I didn't have to mod the t/c shifter,but did anyway,otherwise I thought I would have to make the hole larger to accommodate the longer travel.
dg6772 is offline
post #48 of 191 Old 02-18-2014, 09:36 AM
dg6772
Originally Posted by smbundy13 View Post
even for a 1" body lift?
I don't want to cut corners or anything like that... just figured if I was going to have to put new body mount bushings in, I may as well get a small amount of lift..
"I" would recommend the lift. It has made working on many other things easier;at least for me.
dg6772 is offline
post #49 of 191 Old 02-19-2014, 12:00 PM Thread Starter
smbundy13
1980 CJ7
cool, thanks for the info. I will just go with the 1" daystar kit when I have my body off and adjust whatever comes up.
post #50 of 191 Old 02-19-2014, 01:00 PM
Jeepn-n-tx
I went by Mike Honcho...
Jeepn-n-tx's Avatar
1981 CJ7
Hey brother from another TX mother ...
Going back to your stuck torx bolts ... I had a few that were stuck like that. Tried to weld on nuts to the bolt heads, but guess I wasn't doing it right. I ended up taking a grinder w/ a cutting wheel and VERY carefully I cut a small slice off two sides effectively leaving a small rectangular shape piece over the center of the bolt threads. This gave me something to grab onto with a box wrench of crescent wrench. Worked every time. Just be careful not to buzz straight through the bolt head and into the body when cutting. I replaced everything with hex bolts.
Most everything looks pretty good on your CJ ... now stop taking perfectly good CJs out of TX! ... Move your arse back here instead!
-Scott
'81 CJ7
'85 CJ7 "The Black Whale"
Jeepn-n-tx is offline
post #51 of 191 Old 02-19-2014, 02:11 PM Thread Starter
smbundy13
1980 CJ7
hmm.. thanks for the info! I bought some quality torx sockets so maybe that might help with the bolts.. plus, I have been spraying them with PB blaster for about two weeks!
haha.. I am trying to convince my wife to make the move back to t-town.. maybe next year.
post #52 of 191 Old 02-20-2014, 01:42 PM Thread Starter
smbundy13
1980 CJ7
ok, I am going to (hopefully) start taking the front end off of my CJ this weekend... my question now is, when I unbolt the brake and clutch master cylinders, I would prefer to keep them hooked up to the lines so that I might be able to bleed the systems more thoroughly with the body off... I am most interested in the clutch hydraulic system since I just put a new master cylinder on. I was able to bleed the system but I would like to really be thorough about it...
I am positive that the brake master cylinder is pretty heavy... so I don't want to fubar any of the hardlines... if I need to take off the cylinders then no problem.. would be nice if I didn't have to disconnect them is all.
also, I don't have power brakes..
post #53 of 191 Old 02-21-2014, 04:06 AM
dsfd722sts
1980 CJ7
have you decided what kind of "gasket" your goiung with under the tank and between the skid? I hear neoprene or bike tube rubber especially on the straps. the guy at 4wp told me to get a semi tire tub and make a gasket, but I seem to think there was a plastic liner in the tank skid plate?
dsfd722sts is offline
post #54 of 191 Old 02-21-2014, 10:32 AM Thread Starter
smbundy13
1980 CJ7
I have not.. I haven't even bought a new tank.. I am going to look at the one that is on my skid to see if it can be salvaged..
post #55 of 191 Old 02-21-2014, 11:25 AM
hasselback
If you need something for between your skid and tank, try some self adhesive rubberized flashing. You can get it at Lowe's in the roofing section in 6 inch wide rolls. Just line the inside of your skid with it, and put some on the tank where the straps will rub, and it should be fine.
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
hasselback is offline
post #56 of 191 Old 02-22-2014, 02:41 PM Thread Starter
smbundy13
1980 CJ7
post #57 of 191 Old 02-24-2014, 08:08 AM Thread Starter
smbundy13
1980 CJ7
ok, got some things done on the jeep this weekend.
took the fenders off..
in my efforts to take the fenders off, I only broke 2-3 non-essential bolts..
but I did discover this vacuum reservoir that might not hold a vacuum anymore.
I didn't get a picture of it, but when I took the vapor canister out, it was fully caked with old mud... how essential is that thing and are there any replacements available? is that one of those parts that I must have?
thanks.
also, I am thinking of sandblasting my tub... about how much are people paying for that?
post #58 of 191 Old 02-24-2014, 11:00 AM
dg6772
Sandblasting it's pretty rough on body steel. It can be done,but you may want to go a little less aggressive like.......media blasting. Walnut shells or some other media that will take the paint off,or possibly chemical stripper. Advanced Auto has a stripper that works well.
dg6772 is offline
post #59 of 191 Old 02-24-2014, 11:11 AM Thread Starter
smbundy13
1980 CJ7
yeah.. I was just using sand blasting as a blanket term... sorry for the confusion.
post #60 of 191 Old 02-24-2014, 11:21 AM
dg6772
Gotcha, I checked into this for a nova I'm thinking of doing. Around here it's about 1,000 bucks give or take
dg6772 is offline
