'84 CJ-7 "restore" project - Page 2 - JeepForum.com
post #16 of 191 Old 02-02-2014, 06:00 AM
dg6772
All 3!!!! It took all of them to get mine out.
Dave in Muskegon using JeepForum
dg6772 is offline
post #17 of 191 Old 02-02-2014, 06:11 AM
hasselback
If you have a welder, sit a nut on top of the bolt head, and fill up the center with weld. Then just put a wrench on it.
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
hasselback is offline
post #18 of 191 Old 02-02-2014, 07:03 AM
mscout118
1983 CJ7
I was able to remove mine with an 18v cordless impact driver! Never would have thought it would work but I said what the hey and tried it....of course this was after a couple of days of PB and a little heat, but it worked.
On another note, my right rear body mount bolt is spinning, I'm assuming the capture nut broke loose? Read a few posts about having to cut the bumper. Any suggestions?
Duke
mscout118 is offline
post #19 of 191 Old 02-02-2014, 07:15 AM
dg6772
You may have to go from the inside of the rear tube from the inside wheel well area. Cut it open to access the capture block,repair and close access hole. We did this on my friends but i don't recall removing the tank. I don't think we did.
dg6772 is offline
post #20 of 191 Old 02-02-2014, 07:38 AM Thread Starter
smbundy13
1980 CJ7
Yeah, the rear body mount on the drivers side spins. There is enough room for me to drill a hole with a hope saw then I will just try to find a body plug to put in the hole.
As for heating the roll bar, can I use one of those little propane torches? Or do I need an oxy/acetelane torch?
It would also help for me to gets quality torx set.
Thanks.
DD - 2013 Ford F150 Platinum Eco-Boost
1980 CJ-7 rehab in progress
smbundy13 is offline
post #21 of 191 Old 02-02-2014, 07:44 AM
mscout118
1983 CJ7
Thanks Dave, sorry for the high jack smbundy!
Duke
post #22 of 191 Old 02-02-2014, 08:04 AM
dg6772
Thanks.
I would try propane as it isn't as hot and would do less damage. I used the oxy/acet because that's what I had. Just set mine as low as I could.
dg6772 is offline
post #23 of 191 Old 02-02-2014, 08:14 AM Thread Starter
smbundy13
1980 CJ7
Thanks for the info!!
post #24 of 191 Old 02-02-2014, 05:14 PM Thread Starter
smbundy13
1980 CJ7
Giving some serious thought to taking the body off of the frame so I can just go ahead and address any additional rust issues.
Any write ups/tips on how to tackle this?
Should I go through with this or fix any rust with the body on?
Thanks a lot.
post #25 of 191 Old 02-02-2014, 05:51 PM
seabass1858
1983 CJ7
I was able to get to all the rust with th body on. I did remove all the mounts and just suspend it over the frame so I can see what i was dealing with body mount wise. I will say this, replacing brake and fuel lines with tub on is kind of a pain. I would love to do a tub off but space doesnt permit for me to do that. I did address all the rust though with the tub on though just had to remove everything in my way.
Last edited by seabass1858; 02-02-2014 at 05:56 PM. Reason: super bowl and posting dont go together
seabass1858 is offline
post #26 of 191 Old 02-02-2014, 06:41 PM
dg6772
I did mine with the tub off. While its doable with it on;I would say that this way is easier on your back.
dg6772 is offline
post #27 of 191 Old 02-02-2014, 06:44 PM Thread Starter
smbundy13
1980 CJ7
Ok. I plan on looking at it sometime this coming week / weekend. And make a decision. Right now, the best choice is to take the body off of the frame. But I am not in a rush to make a decision.
post #28 of 191 Old 02-02-2014, 06:54 PM
seabass1858
1983 CJ7
Me on the otherhand upon recieving the jeep I knew I wanted it done by early march so I addressed all the mechanical issues first then jumped onto the body and learned how to weld in the process.
post #29 of 191 Old 02-03-2014, 07:43 AM Thread Starter
smbundy13
1980 CJ7
yeah... I am going to start with removing the roll bar to see just how bad the rust is... then I will decide on removing the body...
post #30 of 191 Old 02-03-2014, 07:54 AM
Blutarsky
Blutarsky's Avatar
1982 CJ7
another picture of the rust damage...
I tried to move the roll bar bolts and broke my torx bit... any pointers on how best to get those out?
I had hell that you can see in my rebuild thread... Ended up having to take it to a friends shop and welding nuts on the top of them, often more than one per torx bolt to get them out. Tried PB blaster, heat, everything that was suggested. It finally took the welding...
Blutarsky is offline
