83 cj 7 - JeepForum.com
post #1 of 9 Old 08-26-2013, 12:01 PM Thread Starter
Rick66002
1983 CJ7
83 cj 7
ok bought this thing 6 years ago, drive it for allmost 2 years and parked it. so just put new tank, sending unit all fuel lines and pump, dist,cap rotor,plugs and wires, and had the carb rebuilt. in town runs great put it in 4 gear and it falls on its nose I have to baby it to get up to 60 mph but it will go. Any xtra gas pedel and she spits and sputters
Rick66002 is offline
post #2 of 9 Old 08-26-2013, 03:52 PM
LumpyGrits
Change the fuel filter.
Does it 'flood' out or run out of fuel in 4th?
Run prem. gas.
Ck your fuel pump for psi.
Get a REAL factory shop manual!
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 9 Old 08-26-2013, 04:57 PM Thread Starter
Rick66002
1983 CJ7
has new fuel filter and pump, but i have access to a pressure tester
post #4 of 9 Old 08-26-2013, 05:00 PM
LumpyGrits
Pull carb and rebuild it.
Bet bowl is a mess.....
LG
post #5 of 9 Old 08-26-2013, 05:02 PM
kovic
1983 CJ5
He said he had it rebuilt. But if you have to baby it to get it up to speed its probably running way to rich. I would pull the carb and rebuild again.
kov
kovic is online now
post #6 of 9 Old 08-26-2013, 05:09 PM
LumpyGrits
kov
Yes he did, and I missed that.
OP-How did it run before the carb rebuild??
LG
post #7 of 9 Old 08-27-2013, 02:00 AM
BagusJeep
1981 CJ7
HAve you checked the timing and the advance mechanisms? Is the engine well grounded? It may be an ignition related issue, remote but possible.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 9 Old 08-27-2013, 09:32 AM Thread Starter
Rick66002
1983 CJ7
LG it wouldn't even run in 4 th had to drop it down to 3 rd and ran good
post #9 of 9 Old 08-27-2013, 09:36 AM Thread Starter
Rick66002
1983 CJ7
the only thing we have not been replaced is the ignition module
