8274 and ligts have blocked my turn signals. Solution? - JeepForum.com
post #1 of 17 Old 10-20-2013, 08:14 PM Thread Starter
10129
I have a WARN 8274 along with a pair of KC's on the front of my Jeep.
As you can see the lights and the winch obscure the turn signals. I'm trying to find a good light that I can mount on the bumper to use as a turn signal indicator. I've thought of the 1 3/4 inch recessed LEDs but I hate to drill that big a hole in the stock front bumper. Has anyone found a good aftermarket light to mount on the bumper that looks somewhat original? I thought about moving my KC's to the outermost set of holes but the turn signal would still be obscured at certain angles.
Any suggestions?
1981 Jeep CJ7
258,T-5, D300, NT AMC-20 & Dana 30 (4.10)
Locked front and rear
10129 is offline
post #2 of 17 Old 10-20-2013, 08:31 PM
CSP
Use little motorcylcle LEDs mounted in/on the front bumper.
CSP is offline
post #3 of 17 Old 10-20-2013, 08:41 PM
nolanbalzarini
thats better than my idea, i was gonna say use your arms
nolanbalzarini is offline
post #4 of 17 Old 10-20-2013, 11:26 PM
82JeepCJ7
1982 CJ7
"Horn broke, watch for finger"
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 17 Old 10-20-2013, 11:29 PM
82JeepCJ7
1982 CJ7
What I ended up doing, I used a piece of 1.25 square tube cut at a 45° angle on both ends /===/ <--- Bad drawing....
That moved the lights out a bit. At least I made an attempt...
post #6 of 17 Old 10-20-2013, 11:35 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'd either get rid of the KCs, or move them outward.
As for seeing the turn signals at different angles, that's what the side markers are for.
Matt
Matt1981CJ7 is offline
post #7 of 17 Old 10-21-2013, 12:01 AM
walkerhoundvm
1981 CJ8
I second Matt's advice.
Another thing I've thought of with my set up:
Is to have dual filament bulbs that could be used as both fog lights and turn signal lights, much like the parking lights in the grill.
walkerhoundvm is offline
post #8 of 17 Old 10-21-2013, 09:25 AM
WindKnot
1977 CJ7
It's a bad angle and it was taken before the Jeep was house broken, but I moved my lights inward. It's a different winch, but it's just another idea.
Oh, and that's what happens when the oil pan skid plate gets pulled downward by "something" in the mud...
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #9 of 17 Old 10-21-2013, 10:47 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Blocking? That's not blocking.
THis is blocking turnsignals:
Extra lights help also.....
John Strenk is offline
post #10 of 17 Old 10-21-2013, 12:54 PM
lucdog
1980 CJ5
John, please tell me that was last year in Ohio, and not this coming winter.
I agree, move the lights out<>.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #11 of 17 Old 10-21-2013, 01:14 PM
John Strenk
1976 CJ5
B
Chance of Snow this Wednesday....
Whats the legality of mounting the turn signal lights on the mirrors?
post #12 of 17 Old 10-21-2013, 01:28 PM
243
1978 FSJ Cherokee
Send me the winch, I will send you a tow strap, problem solved.
Dave's 78 Build
243 is offline
post #13 of 17 Old 10-21-2013, 01:36 PM
wm69
Move your KC lights out. The Jeep SE winches had aux turn signal lights that bolted to the winch plate.
http://www.ebay.com/itm/NOS-JEEP-SPE...#ht_541wt_1399
wm69 is offline
post #14 of 17 Old 10-21-2013, 02:04 PM Thread Starter
10129
I've been looking for some retro lights to match those that came with the winch when it was a dealer option. For those of you lucky enough to have those, are they single filament and only flash when the blinker is on or are the dual filament like the ones in the grill and light up with the headlights too?
1981 Jeep CJ7
10129 is offline
post #15 of 17 Old 10-21-2013, 02:14 PM
jdarg
If you want to stay with stock Jeep parts, TJ front turn signals mount in the fender sheet metal and wouldn't look too bad IMHO.
Frankly I'd just move the add-on lights out more before I start cutting up my fenders though.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
