82 CJ8 steering question - JeepForum.com
post #1 of 6 Old 04-21-2013, 06:38 PM Thread Starter
RoughIdle
1982 CJ8
Hey guys i recently picked up a 82 CJ8 and it has a 4" lift and 35's but it does not seem too turn very well, i was wondering if it is because it is a longer wheel base or is it because of the tires. I can get the wheel to turn from center twice in either direction which seems to be normal and it does not seem to be hitting anything either.
any info can help thanks guys
RoughIdle is offline
post #2 of 6 Old 04-21-2013, 07:17 PM
Trapshooter
In answer to your question, it's probably both. Have someone turn the wheel full travel each way and ensure you are actually hitting the stops at each end.
Good luck........
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 6 Old 04-21-2013, 07:28 PM Thread Starter
RoughIdle
1982 CJ8
Just did that a while ago. Everything seems fine i guess its going to be characteristic of it now, thanks
post #4 of 6 Old 04-21-2013, 07:28 PM
John N
1981 CJ8
Does it have a drop pitman arm on it? Those will cause exactly what you are experiencing. There are fixes.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #5 of 6 Old 04-21-2013, 07:55 PM Thread Starter
RoughIdle
1982 CJ8
Yes it does have a drop pitman arm, does it need a slightly longer one?
post #6 of 6 Old 04-21-2013, 09:37 PM
John N
1981 CJ8
Research "tie rod/drag link" flip.
John N
John N is offline
