82 CJ7 - Trouble Starting - JeepForum.com
post #1 of 14 Old 05-17-2010, 05:00 PM Thread Starter
jeepdude1107
I went to start up my CJ7 last last year. It had been a couple of weeks since it last ran and began to turn over just fine. On the second attempt to start, it didn't turn over at all. I am getting power when I turn the key, but nothing from the engine. I have replaced the starter and the solenoid, but no results. It seems like something is "locked up" and not allowing the engine to start. Anybody have any ideas??? Thanks in advance!!
1982 CJ7
2" Rough Country Suspension Lift
31" x 10.5" Tires
15" American Racing Alloy Wheels
jeepdude1107 is offline
post #2 of 14 Old 05-17-2010, 06:59 PM
Trapshooter
I am going to ask a dumb question here: Have you double checked the battery? Just because the battery shows 12v doesn't mean there are enough cranking amps to start the engine. A shorted cell in the battery will cause the symptoms you have described.
If you haven't already, either try another battery or jump the existing unit.
Good Luck..........
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 14 Old 05-18-2010, 09:28 PM Thread Starter
jeepdude1107
Trapshooter,
Thanks. I had tried to jumpstart the battery twice.....no luck. The battery is about 2 years old.
1982 CJ7
31" x 10.5" Tires
post #4 of 14 Old 05-18-2010, 10:38 PM
Trapshooter
I would still try a different battery; anything you have out of a different vehicle. A shorted cell can "suck" everything on a jump.
By trying a different battery you have eliminated one item from the equation.
Good Luck............
My 401 build:
post #5 of 14 Old 05-18-2010, 10:40 PM
Trapshooter
Just went back to your original post....have you tried to turn the engine over by hand?
Pull all the plugs and make sure the engine itself is not seized.
My 401 build:
post #6 of 14 Old 05-18-2010, 11:25 PM
SecretSquirrel
1980 CJ7
How and where are you checking this?
If the solenoid, battery, ignition switch, and starter all check good, you may want to check or add a starter ground wire. Remember voltage is not amperage, you may read 12 volts, but a bad connection or wire may limit the amps a circuit will carry.
SecretSquirrel is offline
post #7 of 14 Old 05-19-2010, 04:02 AM
Mike Romain
I have seen dirty battery cables cause this, especially when they are dirty where they bolt to the block.
Mike
Mike Romain is offline
post #8 of 14 Old 05-24-2010, 08:21 PM Thread Starter
jeepdude1107
Thanks for the the pointers so far.
I don't have an extra battery to test but the battery tested good when I took it in. The cables are clean. I have a new starter in there is well, but no luck. Where would be the best place to attach a ground wire? How would I try starting the engine by hand? What about the starter relay...is that a possibility?
Thanks!
1982 CJ7
31" x 10.5" Tires
post #9 of 14 Old 05-24-2010, 09:10 PM
Roadymi
1982 CJ7
Run a dedicated ground right to one of the starter mounting bolts.
The previous post about rolling over by hand did not mean to start by hand, just suggesting attemting to roll motor over by hand to make sure it is not seized. If your fan belts are good and tight you should be able to "roll the motor over by hand" by pulling on the fan blade. Just make sure the keys are pulled so someone doesn't inadvertantly hit the switch with your hands in there.
If you don't stop, you won't be stuck
Roadymi is offline
post #10 of 14 Old 05-24-2010, 09:23 PM
jsjpn
1971 CJ5
I would make sure all battery post clamps and connections are good and clean. You may have corrosion up inside the cables causing lost of amperage due to the corrosion. just my two cents! good luck!
jsjpn is offline
post #11 of 14 Old 05-25-2010, 04:35 AM
Mike Romain
Thanks!
Your symptoms of a turn over, then no more imply either the battery is just too low (can still be good, but low in charge) or maybe the starter relay/solenoid has gone bad or a connection on it has gone bad
I use a booster or jumper cable to test grounds. If I run one from the battery negative post to the engine block and the starter then works, I know I have a bad negative cable. They can go bad internally where you can't see it too.
The starter relay is on the fender and is also called a solenoid by some. It can easily have bad connections and is notorious for the bad connections causing a no start.
Mike
post #12 of 14 Old 05-25-2010, 06:37 PM Thread Starter
jeepdude1107
No luck yet....here is what I've done so far:
1) New ground from battery
2) Created ground from starter
3) Replaced Solenoid
4) Replaced Starter
5) Attempt to turn enginer over by hand - unable to move anything (loose belts, anything else I can do to attempt this?)
6) Pulled spark plugs - plugs 4, 5, and 6 were crusty and the rest were dry.
Thanks for your help so far. Any of the above mean anything?
1982 CJ7
31" x 10.5" Tires
post #13 of 14 Old 05-26-2010, 05:13 AM
tigercreek
How are you trying to turn the engine over by hand?
The nut you want to access is the same one holding the pulley with the timing marks.
You should be able to rotate it one way or the other with a breaker bar or a 1/2" drive socket wrench.
If you can't move it, pull your starter and make sure it isn't locked up in the engaged position.
tigercreek is online now
post #14 of 14 Old 05-27-2010, 05:11 AM
Mike Romain
I would be making sure the engine turned over next. Like mentioned use the bolt on the crank pulley or with the plugs out it should even turn by hand.
If the belts are loose enough to slip by hand, then your battery will never got a good charge and will slowly die on you. The alternator takes a few HP to spin up under load and it it can hand slip, no way will it hold under load.
Mike
Trouble starting irmischer Jeep CJ Forum 2 03-28-2010 11:47 AM
Having trouble starting my 83 CJ7 Green091 Jeep CJ Forum 1 03-22-2010 12:48 PM
Starting trouble. jessfireman Jeep CJ Forum 10 03-17-2009 10:47 AM
Starting trouble. jessfireman Jeep CJ Forum 3 11-11-2008 08:38 PM
trouble starting? KRIZB Jeep CJ Forum 7 08-25-2008 11:36 AM
