82 CJ7 Project: "Rustful Dead!" - Page 7 - JeepForum.com
post #91 of 155 Old 05-08-2013, 09:58 PM Thread Starter
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
Some more pics from my TN trip. It rained every day I was there, still a good time. I finally got an OEM windshield frame without rust, and another windshield to boot. I have an extra windshield for sale now
There are a couple of Dad's Fords, a nice flat head and some chicks we met on the golf course.
image-2708004025.jpg   image-171617407.jpg   image-4047791003.jpg   image-354969734.jpg   image-3234812544.jpg
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #92 of 155 Old 05-09-2013, 04:26 PM
Davis77Cj
1977 CJ7
sweet! can you tell me more about the last car pictured?
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #93 of 155 Old 05-09-2013, 06:58 PM Thread Starter
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
It is a run of the mill Mercury Cougar. It is actually a kit you can get to modify a cougar or thunderbird to the 49 Ford coupe rod. It gives it a chop top look but modern conveniences and suspension for riding. It was his first kit build and they did a good job. He is still tinkering with it. He is working on a Alfa Romeo Spider 1600 right now. I think it's a 68 or 69. Wish I was closer to home to get the crew to help on the jeep
HALOjmpr is offline
post #94 of 155 Old 05-09-2013, 07:10 PM
Skerr
My brother had a '63 Alfa Romeo Julietta. It was pretty neat, but Alfa was a problem car. ALWAYS problems with it.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #95 of 155 Old 05-09-2013, 07:28 PM Thread Starter
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
It isn't going to be a full restore any way. I am trying to talk him into a Toyota, Nissan or even Ford 4 cyl in it. It would be fun to drive and reliable. He is leaning towards finding a older ford 4 cyl with no computer for it.
HALOjmpr is offline
post #96 of 155 Old 05-10-2013, 10:36 AM
Davis77Cj
1977 CJ7
That is an awesome set up! man I love it when people take cars and make them thier own
post #97 of 155 Old 05-14-2013, 07:27 PM Thread Starter
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
I finally got to work on the Jeep today. My back has been horrific but nothing I can do but take meds and drive on until my next neuro appointment. Other doc said this time there may not even be a surgical option .... what does he know anyway.
I got all of the manifold unneeded holes plugged, the EGR tube plugs we made installed, and the plugged up egr installed. I was in the middle of installing the Weber when my instructions conveniently blew into an open oil drain pan I have not taken to the recycle bin yet I was still able to read most of it and kept after it. I got the Weber on, double checked every thing, primed it and cranked it. NOTHING. Tried a couple more times and was all stressed out because I had also "cleaned up" all of my wiring mess too. Decided to start with making sure I had spark and when I got around to the other side some knucklehead had undone the coil wires to make it easier to loom everything up and didn't put them back on DOH!
Well, I put the coil wires on and went back and it fired almost immediately ..... ran pretty well. I tried and tried to adjust it but couldn't quite get it just right. It seemed to idle a bit higher than it should with a little miss that made me think vacuum leak. After checking everything I could I finally thought to check the charcoal canister that had been disconnected (I had just reconnected and run new lines for everything with the carb install) ..... YEP, it is bad I am going to O'Reilly's to order a new one tomorrow. I just plugged that one for now. In the mean time I was able to get the idle down and nice and smooth and it accelerates very well. There is one spot towards the top end if you go WOT it hesitates but not the way I drive anyway. I am super happy with the results!
Power Steering, Power Brakes and setting up my half hard doors with TJ soft uppers are the next projects up on the list.
HALOjmpr is offline
post #98 of 155 Old 05-15-2013, 09:49 AM Thread Starter
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
Jeep getting some new shoes today!!! Pics later if I can find new rear center caps.
HALOjmpr is offline
post #99 of 155 Old 05-15-2013, 07:32 PM Thread Starter
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
New shoes and I decided to stay with the 15" wheels. I just think CJs look better with em. I put some new Rancho shocks on while I was at it. Gotta run to the exhaust guy tomorrow because the larger shock tube outs it too close to the new exhaust. Test ride was nice with new shocks and tires. Now to throw the old set on CL and try to recoup some of my money
HALOjmpr is offline
post #100 of 155 Old 05-16-2013, 04:36 PM
Skerr
Not too shabby Bro!! I like 15s also...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #101 of 155 Old 05-17-2013, 12:41 PM Thread Starter
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
Got the new carbon canister in. Put a new coolant overflow tank. Moved the vac trigger from the carb plate down to manifold for the canister. After all of that I set the timing to 8 degrees. Then I went step by step to retune the weber.
It really smoothed out and would idle about as low as I want to make it. No tach so I set it by ear but it is running sweet. The stumble when you go WOT while driving is gone. It pulls hard all the way through. It was even pulling in 5th up inclines. I didn't know CJs could do that . Speedo doesn't work so I will throw the GPS in it when I get back home and see what my hwy cruising speed is.
Amazing how things go when you follow instructions.
HALOjmpr is offline
post #102 of 155 Old 05-17-2013, 03:19 PM Thread Starter
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
Just got back from a quick ride with the GPS. Runs 67-70 easily in 5th and pulled from 67-72 on a slight incline. I wouldn't want to go any faster until I get the steering play out(bad steering box).
Time to start packing for the McDonough,Ga show this weekend! C ya!
HALOjmpr is offline
post #103 of 155 Old 05-17-2013, 10:09 PM
Skerr
McDonough! My brother lives in Stockbridge.
Congrats on the success, Paul. Atta Boy!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #104 of 155 Old 05-18-2013, 04:03 PM Thread Starter
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
Wonderfully, we drove to McDonough last night. Rain all morning. We lose hotel, gas, meals and show fee. Almost back home
HALOjmpr is offline
post #105 of 155 Old 05-18-2013, 07:04 PM
Skerr
Dang... sorry, Dude. What kind of show was it?
Kerrdog
Go Fish! <*////><
Skerr is offline
carter carb , cj7 , msd , nutter bypass , team rush
