82 CJ7 fuel filer hoses - JeepForum.com
post #1 of 5 Old 06-20-2016, 10:30 PM Thread Starter
Chrisinchwk
1982 CJ7
I have an 82 CJ7 with a 20 gallon tank a 1 inch body lift and a YJ tub. My filler and vent line are about 2 inches too short. I also think the PO cut the filler hole a little too far to the right making it worse. I'm not having any luck finding anything but stock length ones.
Any suggestions would be appreciated.
Chris
Chrisinchwk is online now
post #2 of 5 Old 06-21-2016, 11:17 AM
LumpyGrits
Cj
You're gonna have to cut and sleeve both hoses.
I used some copper pipe I found for the filler hose.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 5 Old 06-21-2016, 12:56 PM
StoneTower
You can splice the vent hose with a piece of 3/4 copper tubing. My hose was split and I repaired it temporarily so that I could pass the EVAP Smog test. It worked well. You will have to find something else to sleeve the fill hose.
StoneTower is online now
post #4 of 5 Old 06-21-2016, 02:36 PM Thread Starter
Chrisinchwk
1982 CJ7
Thanks for the advice. Was hoping not to splice the lines but at least I will be able to fill up
Chris
post #5 of 5 Old 06-27-2016, 10:09 PM
Sawfish
1985 CJ8
You may be able to use the longer hoses from a CJ-8 (Scrambler). Check Vintage Jeep for parts.
Sawfish is offline
