82 CJ7 Dana 30 4.88 gear change question - JeepForum.com
post #1 of 6 Old 01-14-2016, 12:58 PM Thread Starter
Chrisinchwk
1982 CJ7
I recently aquired an ARB locker with 4.88 gears on it. Question is do I need a new carrier for the front Dana 30 to go from 2.73 to 4.88. Yukon gears website isn't that helpful.
Any tips or tricks on installing the locker would be welcome.
Chris
Chrisinchwk is offline
post #2 of 6 Old 01-14-2016, 01:23 PM
CSP
Yes, the carrier break for the Dana 30 is 3.54 and down (numerically) and 3.73 and up.
Google ARB installation for starters. The correct pre-load is critical to the ARB working like it should.
CSP is offline
post #3 of 6 Old 01-14-2016, 03:23 PM
Fourtrail
1974 CJ6
CSP is correct on the break. Here is the link to the Yukon part.
http://www.diffsonly.com/store/produ...-373-up-p-3212
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 6 Old 01-15-2016, 09:35 AM Thread Starter
Chrisinchwk
1982 CJ7
Thanks for the replies. I already googled and down loaded the manual. Was more looking for experience type tips.
Thanks for the link
Chris
post #5 of 6 Old 01-15-2016, 09:40 AM
TIPPEDITOVER
In the Lab
TIPPEDITOVER's Avatar
1978 CJ5
Big prybar to pop carrier out, dead blow to smack it back in. Tools needed: Digital vernier caliper, dial indicator, 10-30 inch lb and 40-220 ft lb torque wrench, bearing puller, hydraulic press. There's more just can't remember off top of head.
Set up bearings for quicker easier shim changes. Mix your gear marking compound with some gear oil to thin it a little and put as much force on the gears as you can muster to give a nice clear pattern. This force also helps ensure you've removed all slop from the bearings by adding the appropriate amount of shims. If there is hidden slop your unaware of, it will show itself.
Don't set backlash too tight, you'll burn up the gears. Oil won't make it in between the gear teeth. Don't set backlash too loose. The contact pattern will migrate with accumulated mileage and roll off the edge of the teeth much sooner than if it had been set nominal.
"Societies that lose the cohesion needed for concerted, collective action collapse, either by failing to meet an external threat or from internal conflicts."
Shaun
1978 CJ5 - Rebuild in progress......
TIPPEDITOVER is online now
post #6 of 6 Old 01-15-2016, 04:17 PM
spazzzjeep
1983 CJ7
I've seen a few videos on YouTube for setting preload and backlash. And they seem to do things differently. Is there a recommended video that you guys can suggest?
spazzzjeep is offline
