82 cj7 build "eugene" - Page 2 - JeepForum.com
post #16 of 87 Old 03-13-2011, 03:05 PM Thread Starter
nshefbuch
1982 CJ7
full width swap about to get started and here is a couple pics i snapped comparing the rear 14 bolt mounted up with h1 rims/tires to the jeep as it sits now.
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
post #17 of 87 Old 03-24-2011, 04:49 PM Thread Starter
nshefbuch
1982 CJ7
took the rear axle out last week
post #18 of 87 Old 03-25-2011, 04:39 AM
somfukinguy
1981 CJ8
thats going to be bad
somfukinguy is offline
post #19 of 87 Old 03-25-2011, 07:06 AM Thread Starter
nshefbuch
1982 CJ7
ordered a clocking ring too. i'll be building a flat belly pan as well but axles first. today i'll start tearing out the front axle as i still don't have my brackets to finish up the rear. as of now i have the yj springs in the rear and the 14 bolt sitting under waiting on the brackets.
post #20 of 87 Old 03-26-2011, 05:58 AM
somfukinguy
1981 CJ8
Hey I just got a set of new stock xj springs on eBay for less than 200 shipped. They have adjustable pins in case you decide to stretch the wheel base a little later....I believe they are exactly the same as the wagoneer springs everyone uses. I'm going soa so I figured I wanted stock springs, and these new were almost the same as used ones.
post #21 of 87 Old 03-26-2011, 05:41 PM Thread Starter
nshefbuch
1982 CJ7
That's a good deal on the springs. I can't stretch my rear axle backwards as the gas tank will make contact with the axle. My YJ leafs were free and in good shape. The rear is in and here is what I am working on now. I got these frame out riggers and had to modify one for the steering box brace that clamps it to the frame
post #22 of 87 Old 04-12-2011, 08:04 PM Thread Starter
nshefbuch
1982 CJ7
re-worded the shock mounts. used f 350 shock towers and modified them for the front mounts.
rear
post #23 of 87 Old 04-13-2011, 04:22 AM
somfukinguy
1981 CJ8
I got the same shock towers. You gonna weld them too or just leave em bolted?
post #24 of 87 Old 04-13-2011, 05:32 AM Thread Starter
nshefbuch
1982 CJ7
the front i'm definetly leaving bolt in as the original holes in the frame are sleeved and thats plenty strong. the rear i haven't decided yet if i'll weld them to the frame. as of now the rear has a plate on the other side of the frame clamping the shock towers to it. you think it'll be strong enough not welded?
post #25 of 87 Old 04-17-2011, 02:46 PM Thread Starter
nshefbuch
1982 CJ7
finally able to pull it out of the garage and measure for shocks
post #26 of 87 Old 04-30-2011, 05:09 PM Thread Starter
nshefbuch
1982 CJ7
finally got it out and did the test drive. bolted up the new shocks. bilsteins 5125. no room for reservior so i got these instead. i love them. it took all my strenght and weight to compress them to bolt them in place. rides nice with the stock wrangler springs.
post #27 of 87 Old 04-30-2011, 06:09 PM
diddy2003
Nice job man. It looks great!!
diddy2003 is offline
post #28 of 87 Old 05-01-2011, 06:45 PM
somfukinguy
1981 CJ8
Looks great! What's your steering setup?
post #29 of 87 Old 05-01-2011, 07:46 PM Thread Starter
nshefbuch
1982 CJ7
1.5" tubing .25 wall with 3/4" heims with high steer arms. Stock but brand new steering box from oriellys. I have the bars parallel and all day test drive yesterday shows no need for steering stabilizer. I need a front end alignment but will wait as I am about to purchase 36" tires new. My tires now are in worse shape than I thought.
post #30 of 87 Old 05-02-2011, 04:49 AM
somfukinguy
1981 CJ8
what high steer arms did you use? It looks great. I want to hear more about the shocks when you get the bigger tires on.
amc 360 , axle swap , cj7 , full width , h1s
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
"Gaucho" CJ stepside pickup build jscherb Jeep CJ Forum 1449 11-15-2016 03:17 PM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 08:14 PM
