82 CJ7 4 speed transmission issue. - JeepForum.com
post #1 of 11 Old 06-27-2013, 09:36 AM Thread Starter
ryan_289
A buddy of mine recently bought an 82 CJ7 with the 258 6 cyl engine. It has a 4 speed manual transmission in it that pretty regularly will jump out of first gear. He got a "suposedly" good 4 speed transmission in the deal but we are trying to find out what it is. It is a Borg Warner but the only numbers we see on it are 13-51-097901, 13-52-065-904, and 13-51-066-902 on it.
I would really like to know if this is the same as whats in it. If its different we dont want to step down in grades of trannys.
01 TJ sport. 4.0, manual. SOLD
52 Willys M38. Currently in pieces in my shop. FINISHED AND SOLD.
1948 Willys CJ2A
ryan_289 is offline
post #2 of 11 Old 06-27-2013, 09:50 AM
Dudman5703
The 4 speeds were usually the T4 1982-+( Which I have in my CJ7 ) and the SR4 1980-1981
Both really weak
http://www.novak-adapt.com/knowledge/sr4.htm
http://www.novak-adapt.com/knowledge/t4_t5.htm
"Typical Borg Warner casting numbers found on the T4 are 13-51"
°llllll° Money well wasted
Dudman5703 is offline
post #3 of 11 Old 06-27-2013, 09:52 AM
walkerhoundvm
1981 CJ8
Information we need to know:
1) Describe the shift patterns of both transmissions.
2) Describe the shape of the shifter - straight up and down, or dog-legged.
Pictures of the tranny may also help, but I bet we'd be able to figure it out with the above information.
Three different four speed transmissions were used during the early 80s. Most likely what you have in there is a T4. What you might have as a spare could be either an SR4, a T4, or a T176 (in order of strength and desirability, worst to best).
^^Edit^^ you'll hear "really weak" a lot. The SR4 is considered weak, but plenty of people still have them. The T4 is considered an upgrade from the SR4, it's dependable for daily drivers but not quite as strong as the T176, which seems to be preferred for wheeling and serves as a durable transmission for daily driving, as well. All can be thought of as acceptable transmissions depending on how they're used and abused.
walkerhoundvm is offline
post #4 of 11 Old 06-27-2013, 09:55 AM
LumpyGrits
Whit those #'s, I'll bet you it's a T-4.
It's rebuild time. The 'holding' ring is worn and letting it jump out of gear.
LG
LumpyGrits is offline
post #5 of 11 Old 06-27-2013, 09:56 AM
Dudman5703
I wouldn't rebuild either transmission, look on CL, I got another T4 for $100. Rebuilding it will cost much more.
post #6 of 11 Old 06-27-2013, 10:01 AM
texasdave
texasdave's Avatar
1980 CJ7
With those numbers it appears it is a t-4 transmission. Described as a light duty transmission. What do you plan to do with it? Heavy duty transmissions include the SM-420 Sm-465 NP 435 The T176 is rated as a medium duty xmsn. Go to Novak adapters and read their articles on transmissions and it gives descriptions and other information.
texasdave is offline
post #7 of 11 Old 06-27-2013, 03:32 PM Thread Starter
ryan_289
This will mostly be for running around town and light duty huntin/trail riding. Current tires are 33 12.50 and most likley will not go bigger. Ill check Novaks site to see if I can determine what we have.
Do all of the most likely transmission have about the same first gear ratio? The jeep runs fine as is but I think it would benefit from a lower first gear or different axle ratio.
1948 Willys CJ2A
ryan_289 is offline
post #8 of 11 Old 06-27-2013, 03:36 PM
LumpyGrits
Do you know your R&P?
With 33's and a 4speed, 4:10's take allot of load off the tranny.
LG
post #9 of 11 Old 06-27-2013, 03:41 PM Thread Starter
ryan_289
Not sure on gear ratio. Im going to get him to look for a tag on the differential housings.
1948 Willys CJ2A
ryan_289 is offline
post #10 of 11 Old 06-27-2013, 03:46 PM
LumpyGrits
On the OEM mod 20 rear, there is a letter code stamped into the rear of the housing on the rear axle near the cover on the P/side.
LG
post #11 of 11 Old 06-27-2013, 03:58 PM Thread Starter
ryan_289
Thanks! Will take a look.
1948 Willys CJ2A
ryan_289 is offline
