82 CJ7 4.2L with howell TBI header queation... - JeepForum.com
post #1 of 4 Old 06-12-2011, 08:13 PM Thread Starter
gunrun45
1982 CJ7
Ok. I've got a 1982 cj7 with 4.2 and Howell TBI kit (CA smog legal). Here's my issue: no more smog pump or air tubes and I need a new exhaust manifold. Frankly, I'm tempted to replace the intake manifold and complete exhaust (gotta keep the cat though). Anybody have any sugestions? It basically just needs the oxygen sensor bung and be durable. I was eyeing Borola. Thanks in advance.
gunrun45 is offline
post #2 of 4 Old 06-12-2011, 08:39 PM
mlittle
I put the Borla on mine. My orignal manifold was warped and not sealing well. I was suprised at the improvment in low end power and also the gain in power at cruise speeds. the only problem I ran into was clearance for the clutch linkage, my clutch linkage was a rugged ridge replacement linkage and it wouldn't clear the O2 sensor on the Borla header, I repaired the original linkage by welding up the worn end and reshaping it with a file. now its close but it clears.
1985 CJ7, 258 with TBI, Header, T5, 3:54 gears
mlittle is offline
post #3 of 4 Old 06-12-2011, 08:46 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
As easy as you make that sound, It's not true.
In CA even with the Howeell efi "which deletes many emission components"
Your header needs to be C.A.R.B. certified and also must have an EO#.
Those are what makes a header legal in CA.
The compliant header will unfortunately come with the AIR tube ports which will need to be plugged/caped.
As a side note, Borla's ss header is the best, But it's pricey.
LT1CJ7 is offline
post #4 of 4 Old 06-19-2011, 06:49 AM Thread Starter
gunrun45
1982 CJ7
Ok, anybody else have any thoughts on headers in this aplication?
gunrun45 is offline
howell FI ???s I need Help bigflatblack Jeep CJ Forum 13 05-29-2012 05:29 PM
Howell TBI and Header? ja78on Jeep CJ Forum 4 05-05-2011 10:50 PM
Howell TBI again Jeepit85 Jeep CJ Forum 0 02-25-2010 09:48 AM
Howell Efi bobby0872r Jeep CJ Forum 2 07-29-2009 01:48 PM
258,4.0 head, Howell TBI, Header options? h2oman Jeep CJ Forum 8 07-26-2006 07:10 AM
