'82 CJ7 304 idle WON'T settle down - JeepForum.com
post #1 of 1 Old 01-27-2010, 09:47 PM Thread Starter
dwil023
1982 CJ7
Hey guys just joined, wish I had this when I had my '76 CJ5!!
Here's the problem....... I just picked up an '82 CJ7 with YJ tub conversion already done. I'm trying to get her up to a "rolling" project!
304 eng
Motorcraft 2100 carb
stock disrtbr and ignition system
I got it close to being road worthy and found out Alt wasn't charging batt- had to do Jeephammer's diode fix(THANKS by the way)
I get it running in the garage idling great and test drive stumbles on acceleration. Then if idle is TOO high runs great on the test drive. Chalked it up to carb issues.
last night got it to where I was happy on both ends. This morning drove it to the train station (about 3 miles) halfway there idle shoots WAY up again and can't get it down. I have noticed that the #1 plug wire is almost 180deg out from the vac advance!!
I know alot of these questions come up, I'll try and get any request info out as soon as I can.
-Should I pull the distributor and install it 180deg back as per the diagrams in the manual?
-and then start with timing-then carb?
-I don't think the PO installed a voltage reg, would that contribute to the problem?
Thanks for ANY help!! I'm sure I'll be back!!
Dan
dwil023 is offline
AMC 258 4.2L won't idle jpd1899 Jeep CJ Forum 6 01-30-2009 08:56 PM
258 will run but won't idle Reddy012 Jeep CJ Forum 15 01-01-2009 07:06 PM
Idle Mix and Idle Speed on Weber jennandal Jeep CJ Forum 2 01-28-2008 07:41 PM
Bad Idle madadsnt Jeep CJ Forum 5 05-10-2007 07:11 PM
settle the gas tank dispute once and for all crypt2night Jeep CJ Forum 7 04-14-2004 01:08 PM
