82 CJ5 oil spray at highway speeds - Page 2 - JeepForum.com
post #16 of 19 Old 10-11-2013, 08:32 AM
jcwebber
So far, no resolution, but I'll post it once I do. Let me know if anyone has encountered it and resolved it.
jcwebber is offline
post #17 of 19 Old 10-11-2013, 08:37 AM
adman02
1979 CJ7
I had a similar issue. In my case, the plastic line that runs from the engine to the oil gauge was leaking. I replaced it with a copper line (fairly common item at the parts store) and no more oil spray.
adman02 is offline
post #18 of 19 Old 10-11-2013, 05:28 PM
draperjojo
1946 CJ2A
You may want to do a compression test across the cylinders just so you have an idea on the engine condition. Someone earlier in the post mentioned bad rings pressurizing the crank case. I had the same problem back in the 70's. I did a compression test and had some low numbers. When I did the engine tear down, the pistons fell out....haha. Funny thing was the engine didn't smoke noticeably....Had LOTS of power after the rebuild tho!
draperjojo is offline
post #19 of 19 Old 10-11-2013, 05:33 PM
LumpyGrits
Make sure you have the CORRECT, PCV Valve installed.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
Highway speeds Fitch Jeep CJ Forum 22 01-26-2012 12:37 PM
High idle after highway speeds hp_lovecraft Jeep CJ Forum 1 09-03-2011 01:38 PM
oil spraying everywhere at highway speeds rak09 Jeep CJ Forum 18 05-12-2010 07:35 AM
Highway Speeds? manderson2228 Jeep CJ Forum 11 04-07-2010 09:04 AM
What will ride better at highway speeds redlinedcj Jeep CJ Forum 5 02-01-2005 05:42 PM
