82 CJ tub swap - Page 2 - JeepForum.com
post #16 of 24 Old 09-22-2013, 08:32 PM
Jeep149
1982 CJ7
Originally Posted by pipster453 View Post
Do have measurements where the hole is by chance??
Jeep149 is offline
post #17 of 24 Old 09-22-2013, 09:16 PM
dg6772
why not convert clutch to hydraulic? using an external slave cylinder for an S-10.
Just a thought....
Dave in Muskegon
dg6772 is offline
post #18 of 24 Old 09-22-2013, 09:20 PM
dg6772
Originally Posted by Jeep149 View Post
This is how I made my CJ tailgate work with my YJ tub..
on mine I cut open the rear tube ,from underneath and put in angle-iron that I drilled and tapped so I could replace if necessary.Then made covers for the holes to gain access later.
Dave in Muskegon
dg6772 is offline
post #19 of 24 Old 09-23-2013, 05:08 AM
pipster453
1981 CJ7
Ill try to get measurements this evening.
pipster453 is offline
post #20 of 24 Old 09-23-2013, 10:22 PM
Jeep149
1982 CJ7
Thnaks
Jeep149 is offline
post #21 of 24 Old 10-11-2013, 07:59 PM Thread Starter
McDiesel45
1982 CJ7
Thanks for the info everyone, hopfully I'll be finished soon. Battery tray didn't even think about. Sounds a little easire to get a yj windshild frame.
Again thanks
Mike
McDiesel45 is offline
post #22 of 24 Old 10-12-2013, 06:38 AM
keith460
Jeep. There's Only One
keith460's Avatar
Ive been working on this as well... I was wondering if anyone has had to drill a hole for the clutch linkage to go through the firewall???? I dont have a hole in mine.. just wondering if it just my YJ tub that doesn't have it or its on all of them??
If you still need to know where the clutch rod hole needs to be on a CJ or YJ tub, here you go.
I had to do the same for a Repli-tub from the Philippines that did not have the hole for the rod.
1984 CJ-7 Renegade
keith460 is offline
post #23 of 24 Old 10-22-2013, 05:50 PM
pipster453
1981 CJ7
I am really sorry about not replying like I said I would. I got called out of town and then life has been crazy. So glad someone else posted it. Again sorry! How's the project going?
post #24 of 24 Old 12-22-2013, 11:34 AM
KristPJ
1976 CJ7
i don't know if it is to late or not, but one thing you can do for the body, not to move the body mounts on the frame is buy the outter rails from classic enterprise(CJ 7 one's) if yours are not in great condition! this is what i did for mine! for the rear cross member someone had the autocad drawing of the cj one so i modified it for the yj tub! instead of modifing the stock one, more solide than factory, in 3/16 ...if you dont want to get one build you can mesure the distance and cut then flipp the extremities so the fit with the tub, one guy here i thing certifablejeep did this! works good if crossmember is still good to go but if you plan on changing it your better off with the drawing i have! it cost me about 120 for the 2 rails and 90 to get the cross member build ! if you want the drawing let me know in pm ill send it
http://www.jeepforum.com/forum/f22/project-cj7-pj-edition-complete-rebuild-1628105
KristPJ is offline
