81 cj7 wiring id??? - JeepForum.com
post #1 of 6 Old 07-01-2013, 10:04 AM Thread Starter
delort530
1981 CJ7
81 cj7 wiring id???
HEY, i WAS TRYING 2 FIGGURE OUT WHAT THE 2 WIRE PIG TAIL GOES TOO THAT EXITS THE TAIL LIGHT HARNESS AT THE TOP LEFT REAR CORNER OF MY 81 CJ7, RIGHT BEFORE IT GOES THROUGH THE QTR PANEL/ WHEEL WELL FLOOR, BY THE REAR ROLL BAR MOUNT. THANKS
delort530 is offline
post #2 of 6 Old 07-01-2013, 10:10 AM
Jeeprage
Jeeprage's Avatar
I think it is hard top connection for dome light or rear defroster. I have the same but no top.
2015 JKU - 6m
Jeeprage is offline
post #3 of 6 Old 07-01-2013, 11:03 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yeah, pretty sure it for the dome light. !!
John Strenk is offline
post #4 of 6 Old 07-02-2013, 06:01 AM Thread Starter
delort530
1981 CJ7
Ok thanks. I,ll hook up a test light to see
post #5 of 6 Old 07-02-2013, 06:26 AM
John Strenk
1976 CJ5
Connect the test light across those two terminals to see if the circuit works.
When you turn your headlight switch dash light dimmer to full+, the lights should go on.
If you connect one test light lead to ground, one side of the terminal will be hot., the other side not do anything.
IF you connect one test light lead to Battery (+) the other terminal will light up when the headlight switch dash light dimmer to full+. This is indicating the ground connection in the headlight switch is closing.
post #6 of 6 Old 07-02-2013, 10:08 AM Thread Starter
delort530
1981 CJ7
great info. thanks a bunch
