81 CJ7 Under Hood Clean Up - Page 2 - JeepForum.com
post #16 of 24 Old 03-21-2013, 02:45 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by BagusJeep View Post
Minimum vaccum line is the one that connects the distributor to the carb. Whether manifold vacuum or ported is oft debated but if it ain't connected the vacuum advance is not going to do anything for you.
Second most important is the manifold vacuum to brake servo. This can be eliminated by taking the servo off but generally it works better with one.
After that there is all sorts of stuff you can hook up. I make do with just the above, my EGR valves are all non operable, the tank is vented through the gas cap, the TAC was lost years ago etc.
Don't forget the PCV system that sucks out harm full crankcase vapor. Unless you want to run a road draft tube but the crankcase needs to be vented.
John Strenk is offline
post #17 of 24 Old 03-21-2013, 02:47 AM
John Strenk
1976 CJ5
Originally Posted by DYontheForum View Post
How do I know if my fuel cap is vented?
If it's stock, it's not vented, Venting was done through the evap container on the fire wall.
If the o-rings on the cap are cracked and rotted. then it's 'vented'
post #18 of 24 Old 03-21-2013, 03:10 AM Thread Starter
DYontheForum
1981 CJ7
Can I buy a vented cap so I don't have to run the canister?
DYontheForum is offline
post #19 of 24 Old 03-21-2013, 10:30 AM
John Strenk
1976 CJ5
Good question. I don't know but I found out most Locking gas caps seat so poorly they vent all the time. E-check cant even get them to fit on their tester so I pass all the time...
post #20 of 24 Old 03-21-2013, 11:01 AM
jeep1000
I have fuel coming out of my gas cap. Is it vented to well? Haha.
Jonathan
'86 CJ7, I6 258 four speed manual. See ya on the trails!
jeep1000 is offline
post #21 of 24 Old 03-21-2013, 05:24 PM Thread Starter
DYontheForum
1981 CJ7
Anybody have any idea what this is?
post #22 of 24 Old 03-21-2013, 05:31 PM
adams1985cj
Egr valve
You donít buy it you build it!!
adams1985cj is offline
post #23 of 24 Old 03-21-2013, 07:46 PM Thread Starter
DYontheForum
1981 CJ7
Do I need it or should I plug it off?
post #24 of 24 Old 03-21-2013, 10:56 PM
adams1985cj
Nope
