-   -   81 CJ7 Under Hood Clean Up (http://www.jeepforum.com/forum/f8/81-cj7-under-hood-clean-up-1495612/)
DYontheForum 03-18-2013 09:19 PM
As I am starting to put my Jeep back together I realized how bad the rats nest of wires in the engine bay, original 30, is. So I wanted some good ideas to clean it up. I was thinking about going to HEI, which would remove some stuff but I'm not sure what. Maybe the painless wiring harness would be a good idea, but there is not much wrong with my factory harness.
Also I have a mess of vacuum lines that I have no idea what to do with, I will get pics tomorrow.
BagusJeep 03-18-2013 10:40 PM
They are not that difficult to marshal back into the original wiring looms. Get the original diagrams for the routing and it will start to make sense.
A few cable ties will help get them together.
I then use flexible conduit, the sort you can get for computer wires, and wrap each part of the loom in that with a few cable ties on the outside to hold it together.
When you hav that you will notice your rat's nest is under control.
DYontheForum 03-20-2013 12:31 PM
3 Attachment(s)
What is this thing?
Attachment 589692
What is this hose for?
Attachment 589693
Is this supposed to be capped off?
Attachment 589699
sgtbookie 03-20-2013 01:22 PM
Get your favorite beverage then Check out this site: http://home.sprynet.com/~dale02/
Great site for figuring out what all the crap under the hood is!
cj5russ 03-20-2013 01:34 PM
Oh wow, awesome site.
I can chime in that 3 nipple fitting in the block is a temp activated vacuum switch. I plugged mine with a brass plug.
Qualitycfi 03-20-2013 07:06 PM
Here's my Clean-up!
1 Attachment(s)
Works great now without the new Weber 38 installed (not pic'd).
Qualitycfi 03-20-2013 07:07 PM
Ooops
Sorry, misspoke. With the Weber 38..
DYontheForum 03-20-2013 08:09 PM
How did you get it that clean!?
What is the temp activated vacuum switch for?
cj5russ 03-20-2013 08:23 PM
Not too sure, mine were unhooked and filled with dirt when I got mine, I just left them eliminated. I'm still putting my engine back together and not to the vac lines yet. I know there are a ton of vacuum lines stock on these. This may help. http://home.sprynet.com/~dale02/vactails.htm
lucdog 03-20-2013 08:35 PM
I believe this is called the CTO switch. One of its functions is to, when the engine get to a certain temp, open the heat riser flap in the air cleaner. I "think" the other line goes to the vacuum canister. I put a mechanical temp gauge in its place.
Bill
DYontheForum 03-20-2013 08:58 PM
Ok how bout this. What are the minimum vacuum lines I need to have my 304 run properly?
BagusJeep 03-20-2013 09:21 PM
Minimum vaccum line is the one that connects the distributor to the carb. Whether manifold vacuum or ported is oft debated but if it ain't connected the vacuum advance is not going to do anything for you.
Second most important is the manifold vacuum to brake servo. This can be eliminated by taking the servo off but generally it works better with one.
After that there is all sorts of stuff you can hook up. I make do with just the above, my EGR valves are all non operable, the tank is vented through the gas cap, the TAC was lost years ago etc.
BagusJeep 03-20-2013 09:23 PM
Great engine bay but is your fuel filter upside down?
DYontheForum 03-20-2013 09:27 PM
How do I know if my fuel cap is vented?
The time now is 04:35 AM.
