81 CJ7 Fuel/temp gauge troubleshooting - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 81 CJ7 Fuel/temp gauge troubleshooting
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 01-20-2015, 10:10 PM   #1
topherbarrow
Hey Guys,
I've been reviewing several threads on troubleshooting the CJ speedo gauges. However, I've been using my test light to troubleshoot and have some awkward results.
When I remove the gauge and clip a direct ground to the negative terminal of the battery, I get the below:
- I terminal, I get power.
- A terminal, I get a solid light.
- S terminal, slightly dim solid light.
The A terminal should blink, right?
When I remove the ground:
- A terminal, flashing light.
- S terminal, nothing.
I also get power to the fuel sending unit line. Haven't tested the unit itself as I didn't want to drop tank.
Any thoughts?
topherbarrow is offline   Reply With Quote Quick reply to this message
Unread 01-21-2015, 03:37 AM   #2
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by topherbarrow View Post
Hey Guys,
Any thoughts?
Did you actually remove the wires from the gauge or the gauge from the speedometer?
If the gauge was connected and the case grounded then you should see "A" Flashing with a test light. "S" should be flashing also but dimmer.
With it flashing in the second case doesn't make sense unless your fuel tank is almost full.
What does he needle do in each case?
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 03:06 PM   #3
Willyc
1982 CJ7
I just went through weeks of troubleshooting gauges on my 82 CJ7. Oljeep.com has a TSM available for free download and it was great for troubleshooting, Also found a link on the web "Basic Troubleshooting for CJ Gauges" by John Strenk. My problem turned out to be a dead short on the hot lead for all my gauges near the ignition switch. Fried the temp gauge.
Willyc is offline   Reply With Quote Quick reply to this message
