81 CJ7 Clifford 258 Engine flutter - Page 2 - JeepForum.com
post #16 of 18 Old 06-24-2013, 01:39 PM Thread Starter
KnoxButler
1981 CJ7
UPDATE:
Hey guys, so iv spent some time on the Jeep and preformed the "Team Rush" upgrade with the larger cap, new rotor, wires, and spark plugs. This helped but I don't think this is causing my problem. After playing around with it and doing some research I found that the carb. seems to be way out of tune. So before I do anything else iv started a new thread dedicated to upgrading vs rebuilding my carb. Here's the link http://www.jeepforum.com/forum/f8/81.../#post15601432
Thank you all for your advice, ill report back to this thread with any improvements in the flutter.
-Knox
KnoxButler is offline
post #17 of 18 Old 06-25-2013, 02:07 AM Thread Starter
KnoxButler
1981 CJ7
UPDATE: I did a little work on the carb. taking out the idle tubes and giving them a thorough cleaning with carb. cleaner. My results were spectacular. My idle smoothed way out! Before I could only smooth the engine out a little by pulling the choke out and closing up the carb. Now open or closed it doesn't matter always smooth.
Im still getting a little bit of a flutter at higher RPMs but iv got my fingers crossed that that's a vacuum leak.
-Knox
post #18 of 18 Old 06-30-2013, 08:33 PM Thread Starter
KnoxButler
1981 CJ7
UPDATE: Problem solved. I did a complete rebuild on the carb. and adjusted everything back to stock settings. I think the floats were set to sit to low in the bowl.
Thank you everyone who helped!! I really appreciate it!
-Knox
258 , carberator , carter carb , cj7 , engine
