81 CJ5 wont idle on start up just dies! HELP - JeepForum.com
post #1 of 9 Old 10-13-2011, 03:40 PM Thread Starter
Rammstein142
1981 CJ5
Hello, this issue just started today, i noticed the other day it was idling low so i adjusted the idle and it ran fine. Today tho after going over a few bumps i normally go over in the road it began to not idle anymore and ended up dying. By the time i got to work i couldn't get it to stay on, i need help as this is a daily driver and i haven't really done to much work besides the basics of oil and tune up parts. All the work i usually hand it over to the local 4x4 shop but if this is something easy to fix id love to do it myself as it would be much quicker! Thanks!
Rammstein142 is offline
post #2 of 9 Old 10-13-2011, 03:57 PM
BioTex
1979 CJ7
Do you have any idea what engine/carburator/ignition system you have installed?
Over the years things get changed alot, so there is no way for us to know, but it helps take the guesswork out.
Sounds like a fuel issue so far...
Even pictures would help.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3 of 9 Old 10-13-2011, 04:02 PM
skizriz
1978 CJ7
Checking for vacuum leaks would be a good place to start. And the cheapest.
skizriz is offline
post #4 of 9 Old 10-13-2011, 04:08 PM Thread Starter
Rammstein142
1981 CJ5
Im not sure terribly on the model of it but i can get you some pics in a few and put them up. Now you mentioned fuel issue, could it have anything to do with the crack in the hose going from my fuel tank to the fuel filter in the rear. I noticed the other day it was leaking and im planning on replacing it tom, but was wondering if maybe thats what is causing this issue? Again tho i will have pics up in a few! Thanks
post #5 of 9 Old 10-13-2011, 04:19 PM
mopar346
Yes, if it splits it will suck air instead of fuel. Not to mention the danger, fix it first before you do anything else.
Careful your character's showing
mopar346 is offline
post #6 of 9 Old 10-13-2011, 04:42 PM
BioTex
1979 CJ7
Ramm,
It is very possible that the rubber hoses are the original ones installed from the factory. If it were mine, I would replace ALL the rubber hoses related to the fuel.
Todays fuel (read Ethenol) is not the best for rubber hoses made back then.
It doesn't take much of a leak to get real expensive. It is worth it to get them new. Welcome to the world of CJ's!
Currently:
BioTex is offline
post #7 of 9 Old 10-13-2011, 04:58 PM Thread Starter
Rammstein142
1981 CJ5
Yea they look as if they haven't been changed in quite some time the crack is around the clamp and has had a slow leak to it, but im fixing to go take pics of it all and see what you all think, i really appreciate the help! This cj is loved to death, but its time for it to become a little more reliable!
post #8 of 9 Old 10-13-2011, 05:43 PM Thread Starter
Rammstein142
1981 CJ5
Pics of Carb and cracked line.
https://www.facebook.com/photo.php?f...type=3&theater
also do you think i could place some tape over the cracked lines or fill them in with super glue or something so i can make it home if thats the issue causing it to not run?
post #9 of 9 Old 10-14-2011, 05:45 AM
BioTex
1979 CJ7
Looks like a Carter YF carb to me. That would mean you have the 4 cylinder engine correct? Hard to tell in the close ups.
I'm thinking fuel starvation at this point, so a couple of things come to mind to check or repair.
You could have a plugged filter. I would start there. Change it out.
If that doesn't fix the problem, I would suspect the idle passages are plugged. This means a carb cleaning or rebuild. About $30 in parts if you do it yourself.
Another thing could be the EGR not working. They do get stuck occasionaly, and need cleaned.
Finally, the fuel pump might be weak. This could be due to it sucking air because of the cracked lines. I'd replace them and take the guesswork out.
Oh, and make sure there are no vacuum leaks.
Currently:
BioTex is offline
1976 CJ-5 starts fine, wont idle. dies without throttle Ryan546 Jeep CJ Forum 5 09-27-2011 10:56 PM
'78 cj7 engine dies - will not idle RougeOne Jeep CJ Forum 2 09-08-2011 11:32 AM
dies at idle 1911Tyler Jeep CJ Forum 19 03-09-2011 10:42 PM
CJ wont idle, drives fine but dies at a stop... JeepinYahoo Jeep CJ Forum 0 04-07-2010 12:19 PM
rough idle then dies wh74415 Jeep CJ Forum 4 01-14-2008 06:20 PM
