81 cj5 85 chevy 350 engine WIRING HELP!!!! - JeepForum.com
post #1 of 39 Old 08-21-2013, 10:46 AM Thread Starter
pook
I am starting to wire my jeep cj5 with a 350 swap. I ran ignition wire to starter with south bridge connecttected battery to starter positive and grounded to body (passenger side fender under hood). I havent grounded chassis or motor yet as this was just to test ignition cylinder and starter function as well as identifying wires. Problem is my passenger side brake line started smoking when I attempted to turn ignition on. Is this caused by the frame not being grounded? Does anyone have a wiring diagram for this swap? Please help
Sent from AutoGuide.com App
pook is offline
post #2 of 39 Old 08-21-2013, 10:57 AM
brownbagg
1930 MK Compass
I alway ground starter to frame and come off the same bolt to battery negative
brownbagg is offline
post #3 of 39 Old 08-21-2013, 11:12 AM Thread Starter
pook
But would the frame not being ground cause my brake line to arc? The brake line thats arcing appears to have bare exposed betal below it on the lower radiator support where the passenger side brake line runs under radiator to passenger side caliper
pook is offline
post #4 of 39 Old 08-21-2013, 04:44 PM Thread Starter
pook
Also with the key in off position, connecting connecting battery cables to battery causes starter to attempt to engage... im puzzled
pook is offline
post #5 of 39 Old 09-08-2013, 01:08 PM
joneatsdicks
Did you check the blinker fluid?
joneatsdicks is offline
post #6 of 39 Old 09-08-2013, 02:52 PM
Blakescj7
Why would a brake line smoke? It has no conductivity and hopefully you're not to make it have any lol.
Blakescj7 is offline
post #7 of 39 Old 09-08-2013, 02:53 PM
Blakescj7
post #8 of 39 Old 09-08-2013, 02:57 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Put proper grounds on it! It's try to find a ground!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 39 Old 09-08-2013, 09:24 PM
BagusJeep
1981 CJ7
Ditto.
The brake line is conductive, made out of plated steel it is a fine conductor of electricity even when muddy. Rust however is not.
Put the earth straps on to frame, tub and engine and then run out ground wires to the solenoid, alternator, instrument panel, fuel tank etc. These old Jeeps need a better ground path than a rusty bit of steel. AMC saved a few pennies by having half of each electrical circuit run through the steel structure, 30 years later and rust and poor joints play havoc with it.
Not as sexy as wiring the power cables but it will sort out a number of electrical troubles for you before they start.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #10 of 39 Old 09-08-2013, 09:43 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
When I worked as a Volvo dealer tech in the 80's, we had a customer whose Volvo had a faulty throttle cable. After replacing the cable, the car had the same problem shortly after. As it turned out, the engine ground cable was broken and the draw from the starter was heating up the wire of the throttle cable, melting the liner in the cable housing.
If an electrical circuit needs a specific wire size for the power, it needs at least the same amount of load capacity for the ground.
Max
Mean Max is offline
post #11 of 39 Old 09-09-2013, 09:44 AM Thread Starter
pook
Thanks all for the info problem is all solved. The fuse connector diagram helped a lot.
Now its wired correctly but the clutch safety switch doesn't appear to be working cause nothing happens when I turn the key. The guages come on but when I roll over to start nothing is going to the starter
pook is offline
post #12 of 39 Old 09-09-2013, 10:51 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
No such animal as a clutch safety switch on Jeep CJ or YJ. Safety switches first showed up on the 1997 Wrangler TJ model.
Max
Mean Max is offline
post #13 of 39 Old 09-09-2013, 11:10 AM Thread Starter
pook
That's what I was thinking but I couldn't find out what year they started making them.
Well guess that means something isn't wired right
pook is offline
post #14 of 39 Old 09-09-2013, 02:33 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Or your starter solenoid isn't grounded.
Max
Mean Max is offline
post #15 of 39 Old 09-09-2013, 03:11 PM Thread Starter
pook
Wouldn't it technically be grounded by being mounted in place since the blocks grounded?
pook is offline
