Quantcast '80 CJ7 Brake Booster - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > '80 CJ7 Brake Booster
Old 06-14-2009, 02:00 PM   #1
TKFireman
TKFireman's Avatar
1980 CJ7
Finally found/fixed all vacuum leaks except for the brake booster. When i suck on vacuum hose going to booster, no vacuum at all. Right now the vacuum port is capped off so engine will run properly and I have manual brakes, need to fix this. Anyway to check if the problem is the brake booster or the check valve on the brake booster? Anyway to repair the brake booster if it is the problem?
I've searched for a new brake booster and the only ones i find are for 82-86 cj's. Did they come stock in an '80 or was mine modified sometime in the past? Will one for an '82 work in mine?
Thanks in advance,
Tim
TKFireman is offline   Reply With Quote
Old 06-15-2009, 04:55 PM   #2
TKFireman
TKFireman's Avatar
1980 CJ7
to the top
Old 06-15-2009, 07:20 PM   #3
dawgates
1980 CJ7
Replace the booster. Don't bother with replacing the stock single diaghram, go to a dual diaphram booster. Either that or a hydrobooster.
http://www.offagain4x4.com/Navajo_brakes.html
http://www.vancopbs.com/
http://cgi.ebay.com/ebaymotors/74-86-JEEP-CJ-SERIES-7-DUAL-POWER-BRAKE-BOOSTER-KIT_W0QQitemZ150351012813QQcmdZViewItemQQptZMotors _Car_Truck_Parts_Accessories?hash=item23019e63cd&_ trksid=p4506.c0.m245&_trkparms=65%3A12%7C39%3A1%7C 72%3A1171%7C240%3A1318
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline   Reply With Quote
Old 06-16-2009, 10:01 AM   #4
PavementPounder
Cool as Ice...
PavementPounder's Avatar
The 1995 YJ dual-diaphragm setup is also a popular swap, which you will find threads on here in CJ Tech if you search. If you decide to go that route, I have one of the YJ firewall brackets and you can buy the booster and MC new at the parts store.
This is how NAXJA Midwest Chapter elected officials like to treat their resident users and former multi-year supporters.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline   Reply With Quote
Glock Forum
