80 CJ Tub on an 85 CJ Frame? - JeepForum.com
post #1 of 7 Old 09-14-2010, 10:59 AM Thread Starter
keithmontone
I have an 85 CJ 7 that I am in the process of restoring. In an effort to save $$ for a new tub I am looking to buy a used tub. I found one online for $200 that appears to be in good shape (at least a lot better than mine). It would only need some minor body work.
Question : Would a 1980 CJ 7 tub be easily compatible with my 1985 CJ 7?
keithmontone is offline
post #2 of 7 Old 09-14-2010, 11:09 AM
CSP
Yes. Should be 100% compatible.
CSP is offline
post #3 of 7 Old 09-14-2010, 11:10 AM
CjAl
1980 CJ7
same thing. the frames would have slight differences but as far as tubs go it's the same.
you can also do a YJ tub if you don't mind having a side opening tailgate or doing the work to convert it. you also have to move some body mounts but it's not hard and the YJ tubs are galvanized where as the CJ's are not
CjAl is offline
post #4 of 7 Old 09-14-2010, 11:27 AM
VACJ7
VACJ7's Avatar
So..... you are the guy that beat me to that tub by 24hrs. You will be happy to know the seller has integrity because he would not sell it to me. Said he needed to hear back from you first. Me.... waiting patiently for you to decide.
I think you should go with a YJ tub.
VACJ7 is offline
post #5 of 7 Old 09-14-2010, 11:38 AM
Jim1611
Jim1611's Avatar
In all the bad things we hear all the time it's great to hear the good!
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #6 of 7 Old 09-14-2010, 01:49 PM Thread Starter
keithmontone
Thanks guys, I will pick this tub up...good luck VACJ7!
post #7 of 7 Old 09-14-2010, 01:52 PM
VACJ7
VACJ7's Avatar
So close..... Good luck with the build!!
VACJ7 is offline
body , body mounts , CJ tub , tailgate , tub
back half of cj5 frame to replace rotted cj7 frame? jedsled Jeep CJ Forum 8 05-30-2011 05:11 AM
Glass in 72-75 windshield frame intil 76-86 frame? 4lowherewego Jeep CJ Forum 6 06-29-2010 12:05 PM
cj frame cracked....replacment frame or 1 ton frame for cj neatocj Jeep CJ Forum 17 12-03-2009 08:44 PM
Stock Frame Vs. Mandrel Bent Frame HeepToJeep Jeep CJ Forum 8 05-10-2009 06:28 AM
Frame Repair - cutting frame open to remove rust? Bell-Vegas Jeep CJ Forum 4 04-21-2009 10:44 PM
