Quantcast 80 CJ-7 Front Disc Brake Photo's - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep CJ Forum > 80 CJ-7 Front Disc Brake Photo's
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 03-29-2009, 06:47 PM   #1
RetiredSERE
RetiredSERE's Avatar
1980 CJ7
Not sure what the PO did to this CJ. Either installed the front calipers in reverse or the rims he installed need to me offset out. Either way getting a rub on the aluminum wheels. Have only a hair's clearance between the wheel and the caliper. Then again Autozone could have done it to me again.
Pictures anyone???
Dave
Shoot, Move, Communicate
Admit to Nothing, Deny Everything, Make Counter Accusations...
I Feel Like a Monkey F***ing a Football..
RetiredSERE is offline   Reply With Quote
Old 03-29-2009, 09:10 PM   #2
RetiredSERE
1980 CJ7
bump.. no one want's to try this???
Old 03-29-2009, 09:16 PM   #3
scottymac62
SEAL Team VI
scottymac62's Avatar
1977 CJ5
I'm not clear on what kind of picture you want but this is a pic of my 79 CJ7 with the wheel off.
scottymac62 is offline   Reply With Quote
Old 03-29-2009, 09:21 PM   #4
RetiredSERE
1980 CJ7
Looking for a back side pick. Not sure if the PO had flipped the caliper (left side on right), or just placed bad rims on this jeep. Getting a metal on metal between the caliper and the rim. You by chance have a part number on that caliper? Also is your bleeder valve pointed up or down??
Thanks
Dave
Old 03-29-2009, 09:31 PM   #5
scottymac62
SEAL Team VI
1977 CJ5
Your bleeder valve should be pointed up or it will not bleed correctly.
Brake parts: http://www.jeep4x4center.com/jeep-brake-parts/cj5-cj7-cj8-scrambler/index.htm
Old 03-30-2009, 12:14 AM   #6
mowjoecj
1976 CJ7
The caliper the PO had on only will fit one way. The clearance issue is caused by a realtively large caliper and not enough clearance. either bur some wheel spacers or move up to a 16" rim.
mowjoecj is offline   Reply With Quote
Glock Forum
