80 CJ-5 Trying to get it smog LEGAL ! - JeepForum.com
post #1 of 30 Old 05-24-2012, 02:16 AM Thread Starter
GregoryC
1980 CJ5
Hey guys...
I got the Jeep running and driving. Next I need to fix the brakes. After that.....
This rig is missing the iron exhaust manifold, the catalytic converter and the original carburetor and air cleaner assembly. It will be registered in CA. I don't know if it requires an EGR valve or a smog pump. Did the 1980 models have an onboard computer?
I am still abuzz from a smog victory with my 78 Plymouth Trail Duster. I had an advantage there though since I am pretty familiar with Mopars. The Jeep models are new to me though. I know that the basics apply: Eliminate vacuum leaks, make sure that the engine has NO misfires, keep the engine temps near the limit and make sure all equipment is in place. This is where I need help. ANY clue on what I'll be expected to pay for the following parts?
Carburetor: I checked Rock Auto. I saw one for $200 including core.
Air cleaner assembly.
Iron exhaust manifold.
Exhaust pipe from manifold to Cat converter.
Thanks everyone! Greg
GregoryC is offline
post #2 of 30 Old 05-24-2012, 03:54 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I don't think they had a computer in 1980 but they did have an electronic idle controller.
They also had
EGR
A.I.R. Pump
A.I.R. Air injector manifold into exhaust manifold
A.I.R. Anti backfire valve
Couple of CTO's for Ignition control and Canister purge.
TAC system in Aircleaner assembly
Electric Choke
This is just for the 48 state emission control. Don't know what else is needed for CA.
I have an 80 258 sitting in my barn, I'll snap a few Pics to show you what involved with at least those.
I'll see what else.
John Strenk is offline
post #3 of 30 Old 05-24-2012, 08:14 AM
bkeese
1949 CJ3A
I'll look. I've taken all those parts off of 2 85s in the past year. I would buy a carb from Rock Auto, it took 5 carbs before I found a good one. Several of the rejects had throttle shaft movement requiring bushings, so I just kept returning them until I got one without the movement. I put 4.0 heads on both of mine which required replacing the exhaust manifold. I don't know if they went to the scrap yard. The price of steel is so high things I might have kept, went! Man I had exaust pipes and cats on both. I'll look.
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #4 of 30 Old 05-24-2012, 06:21 PM
cookingguy
1979 FSJ Cherokee
The 1980 cj 5 does gave an ECM computer. I have a stock carter carb i will sell u off of my 83 cj5 it needs to be rebuilt but thay is what was in it for cali smog from the factory pm me if interested in the carb i will let it go very cheap
cookingguy is offline
post #5 of 30 Old 05-24-2012, 06:52 PM Thread Starter
GregoryC
1980 CJ5
Thanks guys.
I found my Chiltons book on emissions 1975-83. Apparantly according to the book, I need the following:
Pre cat converter
Cat converter
TAC with heat stove from exhaust.
Charcoal can
EGR
electric choke
A guy at a local smog shop showed me a book that showed that only ONE catalytic converter was required , but also a smog pump and AIR injection tubes in the exhaust manifold.
I found an AMC Hornet in a local Pick-N-Pull yard. It has a 258 and is complete! It will supply the exhaust and smog pump, plus a few other odds and ends.
The carb on this Jeep is not factory, and the pictures that I see on Rock Auto and at the local NAPA store show the factory carb appearing very similar to the carter 2 barrel used on 318 Dodge/Plymouth models.
GregoryC is offline
post #6 of 30 Old 05-26-2012, 01:40 AM Thread Starter
GregoryC
1980 CJ5
Lucky day! that Hornet had an exhaust manifold that is dated 10-9-79, which I take to be an early 1980 manifold. SCORE! The manifold had the AIR injection rail in decent condition too.
I got the smog pump and diverter, plus all the brackets for $81 on the 1/2 price sale. Heck yeah!
Anyone have pictures of a factory 2 barrel carb for this thing?
GregoryC is offline
post #7 of 30 Old 05-26-2012, 07:50 AM
SoK66
2009 JK Wrangler
Before I'd do all this I'd move to another State.
SoK66 is offline
post #8 of 30 Old 05-26-2012, 12:17 PM
Mike Romain
It is called a Carter BBD. I don't know if it has a feed back on it, but this thread shows a photo of the feedback one, they look the same almost. One has a stepper motor on the back.
http://www.jeepforum.com/forum/f8/st...ypass-1365594/
Mike
Mike Romain is offline
post #9 of 30 Old 05-26-2012, 12:42 PM
titomars
1981 CJ7
1980 Did not have a computer. But you will need the EGR system and the AIR injection system. You will also need a non feedback Carter BBD, the cat., evap. system, TAC system, and spark control systems. For California everything under the hood better look or be stock for 1980. Those guys have no sense of humor anymore! lol
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #10 of 30 Old 05-27-2012, 03:53 AM Thread Starter
GregoryC
1980 CJ5
I'll certainly agree there.
I just finished tuning my Trail Duster for smog compliance. It took 3 attempts to get there and everything was STOCK!
GregoryC is offline
post #11 of 30 Old 05-30-2012, 02:03 AM Thread Starter
GregoryC
1980 CJ5
How common is the carburetor for this thing? I've seen a wide variance in prices for a rebuilt one.
GregoryC is offline
post #12 of 30 Old 05-30-2012, 09:03 AM
Blue83CJ7
1980 CJ7
I have a non- feedback carb from an 80cj7 including the filter housing, smog pump and various other parts I just took off...it was running great, I just drilled the idle tubes, and it comes with the rest of the rebuild kit but I went FI
If you are interested I can send pics and name your price and you can have the whole box (cheap, but shipping might be a bit)
1980 CJ7 - The Grenade
Blue83CJ7 is offline
post #13 of 30 Old 05-31-2012, 01:35 AM Thread Starter
GregoryC
1980 CJ5
A fuelie swap, huh? I just talked with my muffler guy about that subject. He mentioned that several of his Jeep customers have made the switch.
I'm working on this Jeep for a friend. He is more interested in returning the Jeep to stock. It hasn't been registered since 1990 !
"Steve" wanted me to go with a rebuilt carb. A local wrecking yard offers a rebuild service on their carburetors. I'm going to need a special air cleaner assembly as well because of the power brakes. The correct air cleaner is pretty odd looking, being offset the way it is! My muffler guy has a Walker catalytic converter for $200. He said that things changed in 2009 and instead of there being "universal fit" converters, they are now rated by GVWR. The Jeep is listed as a truck, so it requires a different CAT than a car. In 2000 I bought a $60 converter from Summit for a Chevy truck and welded it in myself. Ahhh, the GOOD old days!
GregoryC is offline
post #14 of 30 Old 05-31-2012, 03:41 AM
John Strenk
1976 CJ5
Early Jeep YJ's have the same air cleaner.
Unless your muffler guy is your best friend or family, I think I'd check someplace else on a Catalytic converter.
post #15 of 30 Old 06-05-2012, 01:32 AM Thread Starter
GregoryC
1980 CJ5
I'm not related to the muffler guy. If I knew about a better deal, I'd certainly consider it. I looked at several Cats on the Summit website. The issue there is that if the smog dude gets nosy, a cheaper converter may "red flag" the whole schmere. I've seen prices as low as $70... SURE that sounds great to the wallet, but if the Jeep fails smog testing, it is just money wasted.
GregoryC is offline
CA Smog carnell Jeep CJ Forum 2 10-08-2011 01:25 PM
CA Smog - A win for me! JeffreyCharles Jeep CJ Forum 4 05-03-2011 08:45 PM
79 CJ 5 W/304 smog fonnest Jeep CJ Forum 9 06-24-2009 05:38 PM
304 smog pump picture needed!! Smog pump pulley needed!! 5StarRising Jeep CJ Forum 3 04-03-2007 01:26 AM
What's it take to make a stock 1984 CJ-7 smog legal in Cali.? Empirion75 Jeep CJ Forum 2 10-18-2002 11:14 AM
