8 deg. caster with 35's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 8 deg. caster with 35's?
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 10-02-2013, 05:44 PM   #1
jeepwhore
With the toyota axle swap complete I managed to drive the Jeep down for an alignment last week. Caster came in at 2deg (R) and 2.2deg (L). It's what I expected as the toyota's came with between 1 and 2 deg from the factory. When I upgrade the front axle shafts I'll cut and turn the knuckles but for now I'm just going to correct it with shims so I can drive the thing.
So, I can get 4 deg shims that puts the caster in the mid range of spec or I can go with 6 deg shims to put it around 8 deg. I've read several people suggest to go with a higher caster angle when running 35's or larger. Just wondering what the consensus is on that.
Thoughts?
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote Quick reply to this message
Unread 10-02-2013, 05:53 PM   #2
Spieg8
1984 CJ8
6-7 degrees works fine for me.
Spieg8 is offline   Reply With Quote Quick reply to this message
Unread 10-02-2013, 06:02 PM   #3
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I want just enough caster for good handling. Good "return-to-center" and good tracking at speed. I've always been able to get that with somewhere between 4-6 deg or so. I'm sure there is such a thing as "too much" positive caster.. where the front tires flop side to side too much. Just not sure what that number would be.
Might try the 6deg shims and see how it rides.
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote Quick reply to this message
Unread 10-02-2013, 06:10 PM   #4
gmakra
Mike go with the 6 degree shims as things settle down like your springs and such you will probably see that shift into range.
Now the upshot Mike is you can claim your Jeep is acting squirrely and its not the Molsen Golden on your breath.
gmakra is online now   Reply With Quote Quick reply to this message
Unread 10-02-2013, 10:15 PM   #5
jeepwhore
Thanks guys. And George, if only something so simple would convince the fuzz it's not the operator, lol.
:-D
