8-cyl. Tachometer part needed - JeepForum.com
post #1 of 22 Old 01-07-2016, 10:31 AM Thread Starter
RedNeckCorvette
1979 CJ7
I found this original equipment 8-cyl. tachometer and purchased it on e Bay, when it got here over six years ago it was missing the electrical retainer clip on one [wire] side. Not wanting to cut the affected wire on the jeep, it has been sitting and waiting for a solution far to long.
Does anyone have an idea where I might find, purchase the clip or the clip with the proper wire connector for this device.
Thanks RN
RedNeckCorvette is offline
post #2 of 22 Old 01-07-2016, 10:50 AM
SLO_Ken
I'm pretty sure those are standard Packard 56 type connectors. You may check your local Napa. Or find them online; there are several online sellers that have those connectors. Below is one I've used.
http://www.repairconnector.com/packa...-and-housings/
California 4.0 OBDII Engine Swap
http://www.jeepforum.com/forum/f8/california-4-0-obdii-swap-1530716/
SLO_Ken is offline
post #3 of 22 Old 01-07-2016, 12:18 PM
Spieg8
1984 CJ8
FWIW - The 6 and 8 cyl tachs used the same connectors (maybe you can scrounge one off a 6 cyl tach?). I probably have a couple in the parts pile, I'll check when I get home.
When I was younger, I thought I was Don Quixote... turns out I'm just another donkey-hootie.
Spieg8 is offline
post #4 of 22 Old 01-07-2016, 12:29 PM Thread Starter
RedNeckCorvette
1979 CJ7
I hope it is that simple to find this connector, will get behind the dash the dash to be sure
For some reason I was worried about it being some unusual connector that AMC used. For that reason and the fact there has been no other problems back there for quite some time, I did not get in there to actually look.
The other end is what you described as a Packard 56 split tail male terminal so I might have a tachometer soon where that hole is now.
Thanks Slo_Ken
RN
post #5 of 22 Old 01-07-2016, 12:36 PM Thread Starter
RedNeckCorvette
1979 CJ7
The one thing I do not have is a stock pile of is Jeep wiring components.
Motorcycle wiring connectors have changed so freequently in the last twenty years [Three times for Harley] I was expecting difficulty finding the correct connector.
Thanks Spieg8
RN
post #6 of 22 Old 01-07-2016, 12:42 PM
John Strenk
John Strenk's Avatar
1976 CJ5
It doesn't have to be off a tach. The connector on the harness is the same connector.
So if you find an old wiring harness, you can cut out those connectors right off the ignition switch and use them.
John Strenk is offline
post #7 of 22 Old 01-07-2016, 12:50 PM Thread Starter
RedNeckCorvette
1979 CJ7
Thanks John, wishing I did this long ago.
Going to go through some of my son's junk!
RN
post #8 of 22 Old 01-08-2016, 05:10 PM
lugnut28
lugnut28's Avatar
Let me look and see if I have one. If I do, I'll send it to you.
lugnut28 is offline
post #9 of 22 Old 01-08-2016, 10:26 PM Thread Starter
RedNeckCorvette
1979 CJ7
Thanks lugnut28 I haven't finished looking, but for now I have not found one in the stuff we have here. I hate to look a gift horse in the mouth but this is a # 10 wire that is several inches short.
RN
post #10 of 22 Old 01-09-2016, 12:47 PM
lugnut28
lugnut28's Avatar
Originally Posted by RedNeckCorvette
Thanks lugnut28 I haven't finished looking, but for now I have not found one in the stuff we have here. I hate to look a gift horse in the mouth but this is a # 10 wire that is several inches short. RN
Will this work for you? The length is 12" if not message me and I will make one for you. I have the wire, and the correct terminals. Name:  image-3336808179.jpg
lugnut28 is offline
post #11 of 22 Old 01-09-2016, 02:54 PM Thread Starter
RedNeckCorvette
1979 CJ7
I am not sure, my harness is bundled up and taped where the connectors come together. I will get in there to have a better look. I think it has to be a male connector?
I don't want to trouble you if this is a counter part. But thank you.
RN
post #12 of 22 Old 01-09-2016, 02:59 PM
lugnut28
lugnut28's Avatar
I am not sure, my harness is bundled up and taped where the connectors come together. I will get in there to have a better look. I don't want to trouble you if this is a counter part. But thank you. RN
It's no problem. Just let me know.
lugnut28 is offline
post #13 of 22 Old 01-09-2016, 03:04 PM Thread Starter
RedNeckCorvette
1979 CJ7
I wonder if this tach. is going to be a problem with my after market HEI ignition?
RN
post #14 of 22 Old 01-09-2016, 03:18 PM Thread Starter
RedNeckCorvette
1979 CJ7
lugnut28 / What you are holding is the same connector that is on the tachometer in my picture, post #1.
The tachometer needs a male and a female connector. If I am not mistaken we each have female connectors show in the photographs. I would need the male connector to make this work.
RN
post #15 of 22 Old 01-10-2016, 06:56 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
RN
It shouldn't be a problem, if you pulled power for the HEI from the correct location.
Matt
Matt1981CJ7 is offline
