8.8 swap into cj7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 8.8 swap into cj7
20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!Father's Day & Moving Day Sale!
Unread 07-24-2012, 06:30 AM   #1
dylan0708
8.8 swap into cj7
Ok so I'm attempting to do an 8.8 swap and I thought id throw some pictures up for future reference here. I had been looking for a new rear axle for almost a year and after reading how many people said the 8.8 was a bad swap for a cj due tithe incorrect offset I strayed away from it. However you can pick up an 8.8 with 4.10's and LSD for like $150 $200 bucks so I figured I'd give it my best shot. I picked up my 8.8 for $300, it came with 4.10's LSD new calipers and disks, new brake lines, and all the mounting hardware and 1310 yoke. I spent the last week measuring up and making the jigs to cut down the 8.8 to stock width. Now the only difference between the Amc 20 and 8.8 offset is the Amc 20 is offset towards the drivers side 2" and the 8.8 is offset to the passenger side a considerable amount more. So when all is said and done instead of having a stock 2" offset I'll have a new 1" offset.
My new axle shafts should be in from mosure with the 5 x 5.5 bolt patern this Wednesday, so then all together I'll have a new axle in my jeep in one week. The goal of this project was to get 4.10's into my jeep for as cheap as possible.
8.8 - $300
Mosure axles - $392
Disc redrilled to 5 x 5.5 - $25
Cutting and welding axle tubs - done at home $0
4.10 gears for front - $255 with master install
New d 30 carrier - $75
Grand total - $1047
Now that's not too bad for an entire regear and a new axle.
dylan0708 is offline   Reply With Quote
Unread 07-24-2012, 06:33 AM   #2
82JeepCJ7
1982 CJ7
Did you factor in the cost of converting the rear yolk to fit your drive line U-joints?
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote
Unread 07-24-2012, 06:35 AM   #3
dylan0708
Yep, the 8.8 came with a 1310 yoke do it bolts right to mine.
Unread 07-24-2012, 09:20 AM   #4
82JeepCJ7
1982 CJ7
Ah ok. I know stock they have a flat flange on them.
Unread 07-24-2012, 08:26 PM   #5
Havasu Living
Havasu Living's Avatar
1980 CJ7
I've been banging around this idea as an axle for several years. Very interested in your jig. Whatever axle I do means cutting the length. Post pics.
80 CJ7 5.0 T176 D300 D30 AMC 20 York OBA
Havasu Living is offline   Reply With Quote
Unread 07-24-2012, 08:48 PM   #6
80cj
80cj's Avatar
1980 CJ5
Did you just butt weld the axles tube back together after cutting? My concern has always been the integrity of a butt welded tube. Other than that I think the 8.8 is a good choice. I've regeared a couple for friends and they're quite beefy. Some people still recommend welding the tubes to the housing, though.
80cj is offline   Reply With Quote
