'79 QuadraTrac Lift Question - JeepForum.com
post #1 of 10 Old 10-06-2009, 10:29 AM Thread Starter
Rough85CJ7
I have recently purchased a '79 CJ7 with the 400 & QT tfr case. I want to lift it, but after looking at the rear driveshaft (stubby doesn't even cover it) - I'm worried about the angles for a lifted set up. I already have some 4" lift CJ7 springs that i could use, but don't want to ruin anything. I know guys are doing it successfully - any insight?
Rough85CJ7 is offline
post #2 of 10 Old 10-06-2009, 02:10 PM
jfwireless
1976 CJ7
I am using the Skyjackker J20RS 2.5 inch lift springs in the rear on my 1976 CJ7 304/TH400/QuadraTrac with no issues. I do not believe another 1.5 inches will make any differnce at all.
Jim
jfwireless is offline
post #3 of 10 Old 10-06-2009, 06:58 PM
garbageman
1979 CJ7
I'm running 4" BDS on a 76 with Th400/QT and yes it's steep, but the diff and rear output is in phase. No vibration and still plenty of slip in the drive shaft.
1979 CJ7 - Propane powered 258/TH400/Q-trac- 2015 Project
Sold:
1974 CJ5, 1980 Wagoner, 1976 CJ7
garbageman is offline
post #4 of 10 Old 10-07-2009, 11:21 AM
tankcj
tankcj's Avatar
I had a slight vibration after installing the lift and went with a Tom Woods CV shaft and new pinion angle shims and now I have no vibration.
2011 2dr Rubicon Auto, AEV 3.5" Premium, PSC Brawler Lite front bumper and skid, Evap skid, Raceline Monster beadlocks, 35" KM2s, 5.13 gears, Trailgater, Expedition One rear Bumper and Tire Carrier, ACE Rock Sliders, Warn Powerplant, ORW trans cooler
tankcj is offline
post #5 of 10 Old 10-07-2009, 11:42 AM
Totallymetal
1" TC drop fixed my vibration from the lift, but I want to put a double cardan joint in there to get the ground clearance back. I am not sure if there is enough room to do it. Front was no issue.
2007 JK Rubicon
5.5 Rock Krawler X-factor lift w/37 x 12.5 x 17 BFG KM2s, 5.13 Superior gears
Warn Powerplant HD
Totallymetal is offline
post #6 of 10 Old 10-07-2009, 11:45 AM
tankcj
tankcj's Avatar
You should have no problem. We have the same setup. I think my over all length of the CV shaft was 17.5".
tankcj is offline
post #7 of 10 Old 10-07-2009, 12:52 PM
CSP
Even with 4" of lift you're not in the same ballpark as a CJ5 with a T18/D20 with 3.5" of lift. I had that setup and when my wheelbase was stock the rear shaft was 13.5" long.
CSP is offline
post #8 of 10 Old 10-07-2009, 01:32 PM
danheit
danheit's Avatar
1979 CJ7
Could always do what I did. I stretched the rear 8" and kept it spring under. Made for a much better ride for stability and control. Pretty easy to do as well.
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!!
Build Thread: 1979 CJ7
danheit is offline
post #9 of 10 Old 10-14-2009, 10:19 AM Thread Starter
Rough85CJ7
I'll keep pushing on then - thanks for the insight!
post #10 of 10 Old 10-23-2009, 08:47 AM Thread Starter
Rough85CJ7
I got most of it put back together! With the degree shims installed and TC drop the difference in angle is almost negligible - thanks to all for your input.
Now just to finish the body........
QuadraTrac Emergency Drive Shift Valve and QuadraTrac Lever Info? LiftforPleasure Jeep CJ Forum 20 02-21-2014 03:33 PM
Question to CJ7 Quadratrac owners Faw Jeep CJ Forum 22 10-12-2011 01:06 PM
Quadratrac Question...... peanutfarmer101 Jeep CJ Forum 2 02-22-2008 04:24 PM
CJ quadratrac question jennandal Jeep CJ Forum 4 10-10-2007 09:33 AM
Quadratrac question sixshooter Jeep CJ Forum 1 11-25-2006 02:44 AM
