79 CJ7 Start issues! HELP!?!? - JeepForum.com
post #1 of 4 Old 08-23-2010, 06:11 PM Thread Starter
Dougs79cj7
1979 CJ7
I purchased my 79 cj7 and have LOVED it and all the work that comes with it! I replaced the alternator due to a squeeking and high voltage readings (I think the regulator was going out). Before replacing it, the ground wire to my battery had gotten so hot that it melted the terminal for the cable, so I decided it was time. With the starter replaced, no squeeking or melting terminals! The volts still read a little high, but not more than 16. It is important to note that the previous owner installed a battery cut-off switch. Now all the sudden, the jeep will not crank. No noise from starter at all, volts read 12, drop a little (to 10) when attempting to crank. I thought the heat mayt have damaged starter relay, so that was replaced as well with no change.
The only changes that were made was the alt install, and then, the same day, i noted the horn stopped working. Its hot wire is to the relay (battery) post. any thoughts or suggestions would be greatly appreciated!
Dougs79cj7 is offline
post #2 of 4 Old 08-23-2010, 06:37 PM Thread Starter
Dougs79cj7
1979 CJ7
Ok, I may seem like an idiot answering my own question, but I have found the solution!! I decided to be a man about it and put the answer on here in case someone else is in the situation later. . . LOOSE WIRE ON NEUTRAL SAFETY SWITCH! I know, I should have check there first, but now whoever reads this can learn from my mistake!
post #3 of 4 Old 08-10-2011, 07:20 PM
cwsenn
1979 CJ7
Is your NSS on the steering column or the transmission?
cwsenn is offline
post #4 of 4 Old 08-10-2011, 07:51 PM Thread Starter
Dougs79cj7
1979 CJ7
It is on the column under the dash, topside and tricky work your hand to, but fairly simple.
cj7 , start problems , starter issue , starter relay
Good Start/Hard Start/No Start tigercreek Jeep CJ Forum 2 05-25-2010 07:48 AM
Shifter Issues and don't know where to start.... KSToyz Jeep CJ Forum 8 11-12-2007 10:18 AM
CJ7 304 V8 - Hard Start Issues soccerpapa Jeep CJ Forum 13 07-10-2007 08:32 AM
Cold Start Issues... Still ii311hive Jeep CJ Forum 2 02-17-2006 08:10 PM
now clutch issues to add to my list of issues. gigihurt Jeep CJ Forum 1 01-04-2005 01:38 PM
