79 CJ7 - soft door install - JeepForum.com
post #1 of 7 Old 11-13-2013, 08:54 PM Thread Starter
Frankandsteph
1979 CJ7
So I got some new soft doors, but the door latch does not match to the frame, not even close. Anyone have any latch pictures to show me what I can do?
- frank
Frankandsteph is offline
post #2 of 7 Old 11-14-2013, 06:27 AM
walkerhoundvm
1981 CJ8
I bet if you took pictures of what you've got, we could help you easier
walkerhoundvm is offline
post #3 of 7 Old 11-14-2013, 09:24 AM Thread Starter
Frankandsteph
1979 CJ7
Ok, so the latch that sits on the body needs to be extended ut maybe an inch or so. i could use washers, but it would look ugly. Anyone else have this issue?
post #4 of 7 Old 11-14-2013, 05:41 PM
JustDandee
1983 CJ7
On mine the PO had nuts spacing out the bracket about a 1/2 inch or so. However this was just on one side the other was flush. If they are bestop door you might find the distance by bending the door wire where it slides into the hinge? just a thought.
JustDandee is offline
post #5 of 7 Old 11-15-2013, 04:01 AM
Jeeprage
Jeeprage's Avatar
Can you loosen the door latch assembly and move it further out towards the catch that mounts to the body? I had to adjust mine slightly, though I have the newer latch style on m y 86.
2015 JKU - 6m
Jeeprage is offline
post #6 of 7 Old 11-15-2013, 07:44 AM Thread Starter
Frankandsteph
1979 CJ7
Jeeprage has saved my day....the darn handle moves about 1" inside it sitting area....It fits perfectly!
Thanks
post #7 of 7 Old 11-15-2013, 11:33 AM
Jeeprage
Jeeprage's Avatar
Thanks
That JeepRage is brilliant.
It was about time I gave back to others! It is hard to compete with all the Jeep gurus on here, though I did learn more than I could have imagined rebuilding mine.
2015 JKU - 6m
Jeeprage is offline
