79 cj7 304v8 stalls after warm; won't restart till cool - JeepForum.com
post #1 of 9 Old 11-04-2010, 06:12 PM Thread Starter
mattman1972
1979 CJ7
guys, so sorry; have searched all related topics in forum and cant find the answer i need...79 cj7 with the 304, stock. It starts right up, idles high for a minute, then when warm idles down lower (after i pump the pedal). I can drive it around town for a short period (~15 minutes) and then when it comes to rest at a stop sign/light and idles it will die. Will not restart for a period of time (i assume when its cooled off?) Can drive it on the highway indefinitely with no hiccups, hesitation, etc. then when I exit, same thing applies. Have replaced the ignition module, fuel filter (2x- but clean 1st one), new battery, new fuel pump, new wires, plugs, and has MSD ign. coil and stock (?) motorcraft distributor and what says is a motorcraft carb. All emissions are off/plugged. This is driving me crazy! The fuel lines are close to the header but I cant see a better way to route them. If its a vapor lock, why only do it at rest, not at speed? No hissing out of gas cap when released.
mattman1972 is offline
post #2 of 9 Old 11-04-2010, 07:06 PM
white_2003
1972 CJ5
getting fuel, spark and compression whem it happens?
white_2003 is offline
post #3 of 9 Old 11-04-2010, 09:53 PM Thread Starter
mattman1972
1979 CJ7
definitely have spark and compression...i can hit the key immediately after it dies and it *almost starts again, sometimes does for just a second and then will not restart until it cools down. a buddy of mine says when it happens that he smells gas like its floded but if its idling, how does it flood?
post #4 of 9 Old 11-04-2010, 10:21 PM
sbcranger
i had a similar issue when i first got my jeep home, same exact thing, started up fine warmed up fine would run okay until it got hot and was sitting stationary, then it would start to sputter and eventually stall out. dont recall exactly where the line was that it was getting hot, but it was getting hot enough to cause vapor lock while idling and staying stationary but once i was on the move the air moving over the line was just enough to cool the line enough to overcome the vapor lock.
sbcranger is offline
post #5 of 9 Old 11-04-2010, 10:22 PM
79cj7stone
1979 CJ7
Do you have an electric fuel pump? I had one that would over heat but my motor would just suck fuel through untill i want to slow down and itt would quit. Then I have also been through the hole vapor locking thing and all you can do is try to keep the lines as far awayy from the headers as you can.
79cj7stone is offline
post #6 of 9 Old 11-05-2010, 02:05 PM Thread Starter
mattman1972
1979 CJ7
its a stock (but brand new) mechanical fuel pump. If anyone on this thread is running headers, is it better to run the fuel lines UNDER the header pipes instead of over top? This is one of those suituations where I really didnt pay attention (or take great pictures) when I was reinstalling the fuel lines to the pump. So aggravating!
post #7 of 9 Old 11-05-2010, 02:22 PM
AdamH07
1981 CJ8
not sure if this helps but I had the problem with it not starting back up until after it was cool. turned out my starter was getting too hot being right next to my headers. heat shield cured that.
I know you have additional issues but maybe they are two separate ones?
FYI.. my fuel lines are under the headers
'81 CJ8 Scrambler
'07 JKUR
'12 GC HEMI Overland
AdamH07 is offline
post #8 of 9 Old 07-25-2011, 09:29 AM
jmcollett
1981 CJ7
I am having a very similar problem with my CJ7. Did you ever figure out what was causing your problem?
jmcollett is offline
post #9 of 9 Old 04-07-2013, 07:11 PM
denverdriveby
1978 CJ5
Welcome to the world of overheated Ignition Modules and Hall Effect Sensors
If everything else is new(er) and in good condition then your problem sounds like CLASSIC overheating of the ignition system.
Think about it kids, this guy's Jeep runs great on the highway but stalls out at lower and/or idle speeds and then refuses to restart for a long time --- this is because of two things:
#1: corrosion of the electrical connections inside your ignition components from many years of water condensation
#2: your ignition module and distributor (Hall Effect sensor actually) are at the end of their useful lifespan
----> spray a can of electric contact cleaner onto all the electrical connections & contact points and / or replace as necessary
or it could be vapor locking - CJ's tend to vapor lock sometimes with 10 to 15 minutes of run time usually because the engine gets really hot (thus boiling fuel in the lines and at filter above intake manifold) because CJ's are driven mostly at low speeds where less airflow goes through the radiator and over/around the engine & manifolds
------> replace your gas cap and consider insulating / wrapping your fuel lines in the engine bay area.
denverdriveby is offline
cj7 , stalling at stop
1978 CJ-7 304V8 has no giddup! sweetguardian00 Jeep CJ Forum 4 05-06-2010 11:12 AM
304 takes forever to get warm-sputters, stalls, etc. kg45777 Jeep CJ Forum 2 11-19-2009 04:00 PM
85 CJ7 stalls if I don't let it warm up. zigafu Jeep CJ Forum 2 08-02-2009 06:22 PM
1977 CJ5 304V8 issues 77cj52009 Jeep CJ Forum 19 06-19-2009 09:20 AM
Holley Intake manifold 304V8 piston1 Jeep CJ Forum 6 02-27-2007 06:15 AM
