79 cj5 transmission installation 3 days no progress - JeepForum.com
post #1 of 26 Old 07-07-2013, 03:05 PM Thread Starter
jennkent5454
1979 CJ5
I decided to replace the clutch so we dropped the transmission, we got the clutch installed and the bellhousing on but we cant get the transmission to line up and slide in. We have tried with the skid plate/mount, without the skid plate/mount. Have tried everything even to remove the new pilot bearing to make sure the trans shaft would fit. Im at a loss here about how to get it in.
jennkent5454 is offline
post #2 of 26 Old 07-07-2013, 03:58 PM
LumpyGrits
Did you check fit the new friction plate of the clutch on your tranny's input shaft before the install? You do this to verify the splines are correct for the input shaft.
What did you use to align the clutch disc when you tightened down the p'plate?
LG
LumpyGrits is offline
post #3 of 26 Old 07-07-2013, 04:11 PM
chatham
you can pickup a cheap clutch alignment tool at a auto parts store or even use a old broom handle. like said above you got to make sure that the clutch plate is aligned properly with the pressure plate or you will never get the input shaft in.
chatham is offline
post #4 of 26 Old 07-07-2013, 05:00 PM Thread Starter
jennkent5454
1979 CJ5
LG
I checked to be sure the clutch disc fit on the trannys shaft and the pilot bearing as well- both did fit
I used the allignment tool that was supplied with the kit.
post #5 of 26 Old 07-07-2013, 05:07 PM Thread Starter
jennkent5454
1979 CJ5
on a side note what is the torque of the p-plate bolts? I just twisted one off in the flywheel. should I tap it out or buy a new flywheel?
the tranny and t-case are so hard to Maneuver without the correct tools, thats my main issue, trying to get the tranny shaft lined up with the engine swaying on the 2 motor mounts.
post #6 of 26 Old 07-07-2013, 05:13 PM
LumpyGrits
Good deal
How close do you get the engine and tranny? With in 2-3 inches?? If this...
Take 4 long bolts that will screw into the back of the engine and cut the heads off.
Use these headless bolts as 'alignment pins' to guide the tranny 'home'.
BTW: Those plastic alignment tools ain't the best. Do you have an old input shaft for your tranny? That is really the best tool to use.
P'plate bolt torque s/b 12-15 lb. lbs MAX and use blue loc-tite.
Can you get the broken bolt out??
LG
post #7 of 26 Old 07-07-2013, 05:31 PM Thread Starter
jennkent5454
1979 CJ5
Good deal
LG
the closest I got was about half an inch, but the tranny was a little cockeyed so the holes didnt line up but it was pretty close a few time that longer bolts would have worked.
I dont have an extra input shaft to use but def a great idea for the next time (I hope theres no next time).
Im going to try and tap the hole and see if I can get it out.
any tips on lifting that heavy beast?
post #8 of 26 Old 07-07-2013, 05:40 PM
LumpyGrits
BEFORE you pull the FW.
Center punch to marks. One on the FW down in the bolt area. Then another one right next to the first one on the crankshaft itself.
This way you don't have any chance of loosen balance.
You may need to take it to a machine shop to remove that busted bolt head.
Did the b'head twist off at the surface, or did it break below the surface??
What bolts are you using?? They need to be at least grade 5 certified.
Just lay the FW on your chest and roll out with it. The hard part is put'n that sucker back in and keep'n ALL of you fingers
LG
post #9 of 26 Old 07-07-2013, 05:46 PM Thread Starter
jennkent5454
1979 CJ5
The bolt broke below the surface. I will prob end up taking it the shop tomorrow, they can tap it out and install the tranny. Hopefully it won't cost to much which is why I was doing it myself.
post #10 of 26 Old 07-07-2013, 05:52 PM
LumpyGrits
Don't give up
Learn to do it yourownself
Just use a torque wrench on the FW bolts and on the p'plate bolts.
LG
post #11 of 26 Old 07-07-2013, 08:08 PM
CSP
Center punch two marks. One on the FW down in the bolt area. Then another one right next to the first one on the crankshaft itself.
The AMC flywheel bolt holes only line up one way. They look like they are symmetrical, but they are not.
CSP is offline
post #12 of 26 Old 07-07-2013, 09:52 PM
LumpyGrits
Yeah, I know, just easier to line up that way.
LG
post #13 of 26 Old 07-08-2013, 06:13 PM Thread Starter
jennkent5454
1979 CJ5
Good deal
LG
So p-plate bolts 12-15 lbs
What should the following be?
Bolts that hold the bell housing to the engine?
Bolts that hold the tranny to the bell housing?
post #14 of 26 Old 07-08-2013, 06:19 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I had the same problem with my T5. The fix was to have a helper work the clutch pedal in and out a few times while I pushed the trans toward the engine. That got it in the remaining amount. I can thank Jeepforum for that trick, but unfortunately I don't remember who specifically posted the technique.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #15 of 26 Old 07-08-2013, 06:29 PM
LumpyGrits
Depends on bolt dia and thread. Also the bolts strength specs(GD5, GD8).
Again, GOOGLE is your FRIEND
http://www.repairengineering.com/bolt-torque-chart.html
LG
