79 CJ5 manual shifter service kit? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 79 CJ5 manual shifter service kit?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 12-10-2014, 12:27 PM   #1
BARRACUDA1968
1979 CJ5
I found a shifter service kit on ebay for 80 and newer but nothing for 79. I'm not sure what the years differences are.
I have my shifter apart for carpet installation and I'm missing one of the shifter pins and my gasket is tore.
I may be able to get by with a new pin and gasket but where do I round those up?
If there's nothing out there I'll just make my own but if the service kit is cheap enough I'll just go with new parts.
1979 CJ5
304 3 SPEED
4" Lift
Fiberglass body
BARRACUDA1968 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 02:05 PM   #2
CSP
A kit for 80 and up isn't going to work on '79 and older.
CSP is offline   Reply With Quote Quick reply to this message
Unread 12-10-2014, 02:24 PM   #3
BARRACUDA1968
1979 CJ5
Know of a kit that's available or should I just make my own pin and gasket which is basically all I need. Not sure how much difference a new spring will make. Not a big deal.
1979 CJ5
304 3 SPEED
4" Lift
Fiberglass body
