'79 CJ-5 build "mexicano" - Page 2 - JeepForum.com
post #16 of 56 Old 08-14-2013, 01:43 PM
Jeeprage
Jeeprage's Avatar
Originally Posted by TexasJeepyall View Post
thanks lumpy (lol)
some guys on my other threads made it seem so difficult, saying it would be super difficult to repair and costly, but you make it seem easy enough!
Probably because you didn't post pictures in your previous thread. Now that we see that you still have the original perches in place, we know it is a quick fix.
Depending on tire size, your current set may rub after you go back to SUA with the current springs. If you DO want more height, you'll just need to find some 2-4" lift springs, and keep them SUA.
2015 JKU - 6m
Jeeprage is offline
post #17 of 56 Old 08-14-2013, 01:53 PM Thread Starter
TexasJeepyall
CJ5
how does a 3 inch lift with some 34s sound?
hey atheists,
If God doesn’t exist… then how has anyone really been far even as decided to use even go want to do look more like
http://www.hudl.com/athlete/662931/highlights/35184377
TexasJeepyall is offline
post #18 of 56 Old 08-14-2013, 01:55 PM
Jeeprage
Jeeprage's Avatar
Probably a bit too large. I'm running 3" suspension and a 1" body lift (due to fiberglass tub) and 33s fit perfectly. I don't know what gearing you have, but I wouldn't go too large if you dont have the budget to swap unless you know you're all set.
If this is going to be a Daily Driver, I'd go 2.5" lift and 31-32s, personally. Mine is a 2nd vehicle and for nicer days or snow storms.
2015 JKU - 6m
Jeeprage is offline
post #19 of 56 Old 08-14-2013, 02:12 PM
walkerhoundvm
1981 CJ8
hey atheists,
walkerhoundvm is offline
post #20 of 56 Old 08-14-2013, 02:17 PM
WSS
WSS's Avatar
1972 CJ5
Yep. Good pics make a difference.
WSS is online now
post #21 of 56 Old 08-14-2013, 02:24 PM
Chewtoy
1976 CJ5
Any larger than 33s, and you will have to start looking at cutting the rear wheel wells to let the tire fit at full stuff. A good 3" lift and 33s is a good setup. Just my opinion, but you might look up "Ubolt Flip Kit" for a CJ and that will get your Ubolts up and out of the way.
With a great Jeep comes an empty wallet.
Last edited by Chewtoy; 08-14-2013 at 02:31 PM. Reason: can't pull my head out today.....
Chewtoy is offline
post #22 of 56 Old 08-14-2013, 03:33 PM Thread Starter
TexasJeepyall
CJ5
2.5 inch lift and some 32s? sounds fine with me!
hey atheists,
post #23 of 56 Old 08-14-2013, 03:40 PM Thread Starter
TexasJeepyall
CJ5
are those necessary for the conversion?
hey atheists,
post #24 of 56 Old 08-14-2013, 05:02 PM
Nafpu
2012 KK Liberty
Originally Posted by walkerhoundvm View Post
95 YJ, gone...
80 CJ7, gone...
12 KK, still here...
Nafpu is offline
post #25 of 56 Old 08-14-2013, 05:03 PM
Nafpu
2012 KK Liberty
No, just helpful. It gets the U-bolts pointing up instead of down, reducing snag points.
95 YJ, gone...
80 CJ7, gone...
Nafpu is offline
post #26 of 56 Old 08-14-2013, 05:21 PM
WSS
WSS's Avatar
1972 CJ5
X2!
I have skids on mine and they do get abused.
WSS is online now
post #27 of 56 Old 08-14-2013, 07:38 PM Thread Starter
TexasJeepyall
CJ5
damn these guys really did a number down here
the shocks on the left are placed by using a couple of metal plates and 15/16 bolts with the head cut off in between them, as fillers, in a Z shape.
the ones on the right are attached the same way but flat across
the bottom flat part where it used to be SUA is really close to that thingy running across that turns the wheels (sorry for my lack of mechanical terminology, thats why i made a JF account lol)
in between the block and the springs on the drivers side theres a tiny plate of metal wedged in between, kind of like a make shift shim.
on the right side, there isnt.
i decided not to touch anything till i consult you guys.
1085335_628476913839834_908457631_n.jpg   954358_628476793839846_1603842841_n (1).jpg   1078268_628476623839863_764991050_n.jpg   1082820_628476730506519_1489700681_n (1).jpg   1075167_628476663839859_1096899118_n.jpg
hey atheists,
post #28 of 56 Old 08-15-2013, 11:39 AM
Chewtoy
1976 CJ5
can you post up a pic of the front axle and steering gear from right in front so we can see the whole thing in one shot?
Chewtoy is offline
post #29 of 56 Old 08-15-2013, 11:53 AM
jdarg
How good are you wrenching? Fabing? Welding?
You really need to find some local help from someone that knows their way around CJs and tools or you are in for a long, expensive, drawn out mess assuming you don't give up first.
Based on what we've seen so far this probably has a lot more issues beyond the obvious. What folks say in passing on a forum may "look easy" but they aren't telling you 98% of the details that you need to know to do this correctly. I guarantee you undoing the previous owner's shortcuts won't be nearly as simple as simply bolting up the axles the other way.
I'm not trying to bring you down, and I'm not telling you not to try to fix it, but it sounds like you need a serious mentor that is going to help you do it right, and I don't mean a bunch of strangers on a forum. You can't just post a few pics and expect step-by-step instructions on how to undo this atrocity.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #30 of 56 Old 08-15-2013, 06:05 PM Thread Starter
TexasJeepyall
CJ5
im good enough at welding to work at a welding shop and never see my jobs come back lol
fabing, im okay. im learning.
and what a bummer. when i agreed to the jeep i had no clue how much work it needed, but its too late! my brother in law is going to graduate from UTI in september... but i dont want to wait that long. the previous owners really effed us good.
hey atheists,
