'79 258 smog pipe threads? - JeepForum.com
post #1 of 9 Old 07-09-2011, 11:43 AM Thread Starter
JDeereGn
If I remove the smog pipe from the manifold what are the threads needed to plug the holes? I have seen some info saying bolt and some that say pipe (NPT). thanks to all that have answered my questions in the past
http://s1208.beta.photobucket.com/user/JDeereGn/library/
"All gave some - some gave all"
JDeereGn is offline
post #2 of 9 Old 07-09-2011, 12:25 PM
mopar408
1974 CJ5
they are NOT NPT, they are flare nuts. I'm almost positive they are like a 9/16 SAE thread, really oddball on purpose to keep you from going to FLAPS and easily bypassing emissions hardware. Exactly why you always see 'em welded shut and not plugged,
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #3 of 9 Old 07-09-2011, 12:47 PM
1986cj
You talking the Egr pipe, or the air injection manifold pipe? Never mind I dont know why I read you had a 1979. Old age I guess
1986cj is offline
post #4 of 9 Old 07-09-2011, 12:48 PM
hp_lovecraft
1981 CJ5
I was never able to find a bolt that matched the threads at the hardware store. Others have said they had luck getting something that worked in the plumbing section.
Instead, I ended up filling them full of muffler epoxy, and covered them with a piece of the old piping.
hp_lovecraft is offline
post #5 of 9 Old 07-09-2011, 01:00 PM
1986cj
I just looked at one in the garage on my bench, and 9/16" may be about right but not a pipe thread. Looks to be a fine thread. May be able to find one in brass but for sure it is not a NPT, or none I have ever seen.
1986cj is offline
post #6 of 9 Old 07-09-2011, 01:14 PM Thread Starter
JDeereGn
The pipe isn't hurting anything and the pump was removed by PO. I want to put a manual choke cable on the BBD and it looks like the smog pipe is in the way. Isn't the manifold cast? I can't weld cast and certainly don't want to remove it to weld. Pulling the carb would be much easier to install the choke.
JDeereGn is offline
post #7 of 9 Old 07-09-2011, 01:16 PM Thread Starter
JDeereGn
If it's flare and it looked to be it certainly isn't NPT. Fine thread bolt maybe? I don't want to remove them till I have the proper plugs. Thanks
JDeereGn is offline
post #8 of 9 Old 07-09-2011, 10:03 PM
cdmiller2
1981 CJ5
I was able to put pipe plugs in my 81 258, I cant remeber the size.
cdmiller2 is offline
post #9 of 9 Old 07-10-2011, 08:34 AM
halpeters
1978 CJ7
Here is a link to a set of bolt plugs for an AMC 360...
http://www.teamgrandwagoneer.com/parts/Emissions/more2.html
OOPS - these won't fit the AMC 258 exhaust manifold...
Hal
1978 CJ-7
halpeters is offline
Need help with smog: cj7 augustus Jeep CJ Forum 6 03-21-2010 08:57 PM
304 smog pump picture needed!! Smog pump pulley needed!! 5StarRising Jeep CJ Forum 3 04-03-2007 12:26 AM
smog moach1 Jeep CJ Forum 2 09-19-2006 09:56 PM
Cracked exhaust pipe (on middle pipe from manifold) tholmes3 Jeep CJ Forum 0 02-18-2003 10:03 AM
cj7 smog DaRaidz Jeep CJ Forum 5 02-07-2003 04:20 PM
