78 CJ7 stalled while driving, now it won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 78 CJ7 stalled while driving, now it won't start
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 02-06-2010, 07:36 PM   #1
bogbear
1978 CJ7
Driving down the road CJ stalled, couldn't get it started. Cranks but will not start, replaced the following:
Coil
ICM
SOLENOID
I look down the in carb, and I believe I only see one stream of fuel, could this be a carb issue? Any suggestions?
Thanks
bogbear is offline   Reply With Quote Quick reply to this message
Unread 02-06-2010, 08:58 PM   #2
hp_lovecraft
1981 CJ5
If you pull a plug, do you get a spark?
When that happened to me, I had fuel getting to the carb, so I pulled the plug, and no spark. So, tracing backwards I discovered that a tiny wire from the ignition box to the distro managed to break loose.
Fixed that, and problem is gone, though could be lots of different things.
hp_lovecraft is offline   Reply With Quote Quick reply to this message
Unread 02-06-2010, 09:04 PM   #3
thantos858
1974 CJ5
Have you changed your fuel filter by the carb? I look for simple to hard before just tossing money at it. What where the weather conditions when it happened? couple days before it happened as well.
thantos858 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2010, 09:10 PM   #4
OlivergreenCJ7
X2
Mine had the same symptoms one time and replacing the fuel filter fixed it right up. Cheapest route
1979 CJ7: Gone,but not forgotten
2001 TJ Sport: locked and loaded
OlivergreenCJ7 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2010, 06:16 PM   #5
JeepHammer
Running On Empty...
1973 CJ5
Coil
ICM
SOLENOID
Thanks
I hate to sound like a broken record, but did you start with the simple things...
Like checking the Ignition fuse?
Do the gauges read correctly (or move) when you turn the key switch to the 'Run' position?
If you get the gauges to move, then it's probably not the ignition switch or the fuse.
If you get yourself a $6 test light
(looks like an ice pick with a bulb in the handle and a wire coming out of the handle)
Connect to the battery NEGATIVE terminal, and test (probe) the light on the battery positive terminal...
Once you know what a 'Bright' light looks like (and you have confirmed you have a good ground connection and the bulb is working)
Then take the coil wire connector off the ignition coil.
Probe the RED wire terminal of the CONNECTOR with the key in the 'RUN' position.
You should get a 'DIM' light.
Probe the same 'Red' wire terminal while someone CRANKS the engine (Starter) and you should get a 'Bright' light.
If you don't get the bright and dim lights, there there is an issue with getting power to the ignition coil and probably the module also.
Now, connect the clip of the test light to the POSITVE side of the battery, And probe the NEGATIVE battery terminal.
You should get a 'BRIGHT' light.
This time, probe the GREEN wire terminal of the ignition coil connector.
You should get a BRIGHT light with the ignition switch in the 'RUN' position.
When you crank the engine, you should get a FLASHING light as someone cranks the engine over.
*IF* you do not get the 'Bright' and Flashing lights,
You have a bad ignition module,
Bad ground from distributor to ignition module,
Or you have a bad wire between coil connector and ignition module (Green wire).
*IF* you get 'Bright' and 'Flashing' lights,
Then you are going to need to do some more testing, Probably testing the distributor 'Stator' ("Trigger") for resistance, and that means a Multi-Meter or taking it off and into the parts store so they can test it.
JeepHammer is offline   Reply With Quote Quick reply to this message
Unread 02-07-2010, 06:23 PM   #6
mcktiger
pull the dizzy cap make sure the rotor is spinning
2006 tj rubicon
mcktiger is offline   Reply With Quote Quick reply to this message
Unread 02-08-2010, 05:18 AM   #7
bogbear
1978 CJ7
Turns out to be the connector on the distributor lead wire is bad. Does anyone know if you can buy just the lead or am I looking at buying a whole distributor?
